Planes of Rotation in Solar System & Beyond
In summary, the conversation discusses the alignment of the axis of rotation of the sun with the plane of rotation of the planets, known as the ecliptic or the invariable plane of the solar system. It also mentions the inclination of the invariable plane with the plane of rotation of the sun, the mechanism for the deviation in solar/planet axis inclination, and the inclination of the solar system's plane with respect to the galactic plane. It concludes that there is no strong correlation between these factors and that their alignments appear to be random.
anorlunda
Staff Emeritus
Insights Author
11,308
8,732
I'm not sure if this belongs in Astronomy or Astrophysics.
Todays APOD featured the rotation of the sun about its own axis. It seems to me that the axis of rotation of the sun should be aligned with the axis of rotation of the plane of rotation of the planets, i.e. the ecliptic, or more accurately the invariable plane of the solar system.
Wikipedia says:
Most of the bodies of the Solar System orbit the Sun in nearly the same plane. This is likely due to the way in which the Solar System formed from a protoplanetary disk. Probably the closest current representation of the disk is known as the invariable plane of the Solar System. The Earth's orbit, and hence, the ecliptic, is inclined a little more than 1° to the invariable plane, and the other major planets are also within about 6° of it.​
What about the inclination of this invariable plane with the plane of rotation of the sun about its own axis?
Is there a mechanism to make the deviation in solar/planet axis inclination converge or diverge with time?
What about the inclination of the solar system's plane with respect to the galactic plane?
What about the inclination of the Milky Way's plane compared to those of nearby galaxies?
Are there clusters of galaxies that seem to share co-aligned axes of rotation? If yes, that suggests that they may have evolved from the same protoplasmic disc.
Astronomy news on Phys.org
What about the inclination of Earth's axis of rotation w.r.t. the plane of the ecliptic (23 degrees)? Or that of Uranus (97.8 degrees)?
It's close, 7.25°, but why would you think that? The Sun has lost a lot of its original angular momentum due to radiation, solar wind, and larger scale events such as coronal mass ejections. Those would have to be uniform to make the alignment remain constant.
Keep in mind that the rotations of the planets are not nearly as strongly correlated with the invariable plane as are the orbits of the planets.
As mentioned, its 7.25°.
Mercury is essentially tidally locked. Whatever rotation it had when it was formed is long lost. Venus, too, has lost whatever rotation it originally had. Like Mercury, Venus appears to be in a final configuration. Further out, those gravitational torques become small. The Moon's torque on the Earth is considerably more than that by the Sun. Beyond the Earth, solar torque is just too small.
About 63°. Better, about 117°. The planets rotate somewhat retrograde with respect to the galactic rotation. There is no correlation. This is borne out by observations of other planetary systems. It's essentially random.
Again, it's random.
Flin, P. The Search for Galaxy Orientation in the Local Group in Proceedings of the 192nd symposium of the International Astronomical Union, 1999.
http://adsabs.harvard.edu/full/1999IAUS..192..443F
Likes 1 person
Hmm, that could be. How about precession of the Sun's axis due to gravity of the galaxy?
Galactic tidal gravity may well have an influence on the Oort cloud. At a distance of a light year from the Sun, those small galactic tidal forces become large enough to be a perturbative effect on the weak gravitational acceleration toward the Sun. At a scale of 50 AU (less than a thousandth of a light year), those galactic tides become negligibly small. At a scale of a solar radius, they are essentially non-existent.
What are the planes of rotation in the solar system?
The planes of rotation in the solar system refer to the imaginary planes along which the planets and other celestial bodies orbit the Sun. These planes are also known as orbital planes and are tilted at different angles relative to each other.
How many planes of rotation are there in the solar system?
There are eight known planets in the solar system, each with its own plane of rotation. Additionally, the dwarf planet Pluto and many other smaller objects also have their own planes of rotation. Therefore, there are numerous planes of rotation in the solar system.
What is the significance of the planes of rotation in the solar system?
The planes of rotation in the solar system play a crucial role in understanding the dynamics of the system. They help explain the formation and evolution of the planets and other celestial bodies, as well as their interactions with each other.
Do other systems in the universe have planes of rotation?
Yes, just like the solar system, other star systems in the universe also have planes of rotation. These planes are determined by the initial conditions and dynamics of the system, and can vary greatly from system to system.
Are the planes of rotation in the solar system and beyond fixed?
No, the planes of rotation in the solar system and beyond are not fixed. They can change over time due to various factors, such as gravitational interactions with other objects or external forces from outside the system. However, these changes are typically gradual and do not significantly alter the overall structure of the system.
  • Astronomy and Astrophysics
113K
