Register to reply
Cheap, high density connector for prototyping?
by hxtasy
Tags: cheap, connector, density, prototyping
Share this thread:
hxtasy
#1
Mar13-14, 12:49 PM
P: 95
https://www.sparkfun.com/products/8506
can anyone recommend a connector i can use, to say connect and discconect low current items such as temperature probes, LCDs, for all the prototyping circuits i make.
Circular connectors are high density but they are way too expensive, i dont need it to be rugged. Right now i find stuff laying around similar to that sparkfun link^ that already has pigtails and just solder and heat shrink unto it.
but now im running out of those. computer/molex connectors just dont have the density im looking for.
any suggestions, greatly appreciated.
thanks!
Phys.Org News Partner Engineering news on Phys.org
Identifying long-distance threats: New 3D technology could improve CCTV images
Intelligent system that predicts when alarms might be triggered could greatly improve the management of industrial plant
3D printed nose wins design award
berkeman
#2
Mar13-14, 03:39 PM
Mentor
berkeman's Avatar
P: 41,059
If you get a crimper, you can use RJ-45 connectors. The females have a slight difficulty in that their pin pitch for the PCB end is not a nice clean 0.1" on center, but you can probably find versions that work for prototype boards...
hxtasy
#3
Mar13-14, 04:00 PM
P: 95
Thats interesting, i definitely have rj-45 crimp tools. i dont like dealing with that small of a wire, but this is definitely a cheap solution.
hxtasy
#4
Mar13-14, 05:57 PM
P: 95
anyone else have any ideas?
mheslep
#5
Mar13-14, 07:54 PM
PF Gold
P: 3,098
Quote Quote by hxtasy View Post
Well with higher density comes less pin area to make the connection, so that will likely drive more expensive plating thickness - gold, etc, to provide the same impedance (AC and DC). Also, even if your application is particularly low current and low frequency (if so, what's the point?), there remains a similar mechanical stress per pin experienced during make/break that then must be distributed over less pin, again driving better materials and more precise manufacturing.
In other words, I would not expect the same price per pin in a high density connector that you would see in an 8 pin RJ-45. So then, once the pins are forced to be more expensive, given a more expensive product to start with the industry starts throwing in other features like air-tight seals with O rings, metal shells and strain relief. Voila, you have the expensive circular connectors you are seeing.
The above being the case, a couple alternatives have sprung up:
o Printed circuit board and flex cable (down to 0.5 mm pitch). But then you'll have to pay the overhead for the PCB, contain and mount the PCB if there are environmental issues, etc.
o Redesign your many connections into a high speed serial bus. Many are available with just your kind of problem in mind, and with chip sets to help out.
Okefenokee
#6
Mar14-14, 05:47 AM
P: 245
Are male headers too big for your purposes? They make them all different sizes. They're cheap and easy to work with too. All you have to do is find a female ribbon cable to go with it.
Digikey has a large selection of headers.
hxtasy
#7
Mar14-14, 12:38 PM
P: 95
https://www.sparkfun.com/products/716
RJ-45 break out connector
these are pretty sweet, price isnt too bad
then you can get some cat5 cables from monoprice for 50 cents
berkeman
#8
Mar14-14, 12:39 PM
Mentor
berkeman's Avatar
P: 41,059
Nice find! I searched for a bit and didn't find anything, but that is perfect!
Register to reply
Related Discussions
Use cheap portable compressor to generate cycling high pressure burst Engineering Systems & Design 2
Prototyping automobile components Mechanical Engineering 4
Sink or float, high density low pressure VS low density high pressure General Physics 4
Is there cheap / high productivity way to measure quality of hand tools? Mechanical Engineering 9
Cheap high-density liquid Chemistry 29
