Thread Closed
Light/Diffraction/Refraction
Share Thread
May4-05, 08:32 PM   #1
Hello everyone,
My physics teacher assigned a whole bunch of homework that no one remembers how to do because we haven't taken light for a year and a half. I have gone through all of my old stuff but can't find the right unit, and what I did find isn't in enough detail. I am getting really frustrated with this so hopefully some of you guys can help me out.
1) In a double slit experiment a student used a diffraction grating in which the slit separation was 1.00x10^-4m. A screen was placed at a distance of 4.00x10^-1m from the grating. The student measured the distance from the central maximum to the 2nd order minimum and found it to be 3.00 x 10^-3m. What was the frequency of the light used by the student?
Answer ---> 6.00 x 10^14 Hz
2) Calculate the frequency of monochromatic light used in a diffraction experiment if the 1st order maximimum is observed at an angle of deviation of 28 degrees when the slits of the diffraction grating are 1.00x10^-6m apart.
6.39 x 10^14 Hz
3) Light with a frequency of 4.28 x 10^14 Hz is diffracted by a diffraction grating ruled 5.00 x 10^5 lines/m. On a screen 2.00m from the grating maxima are 7.00 x 10^-1m apart. What is the distance between maxima if the frequency of the light was increased 1.50 times while all other variable remain constant?
Answer ---> 4.66 x 10^-1 m
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
May4-05, 09:47 PM   #2
Ok I finally figured out the last two on my own, but I am still having a lot of trouble with the first one. I think I need to find the wavelength for it and then use the wavelength and the speed of light to find the frequency but nothing will work out for me.
May4-05, 10:18 PM   #3
Your intuition for part 1 was correct.
First find the wavelength of light using the double slit equation.
[tex]\lambda=\frac{dy}{mL}[/tex]
where d is the separation between the slits
y is the distance from the centre line
m is the order number
L is the distance between the grating and the screen
then continue on with your thought process and find the frequency using:
[tex]f=\frac{c}{\lambda}[/tex]
May4-05, 11:45 PM   #4
Recognitions:
Homework Helper Homework Help
Bross7's equations are correct. You may keep units in meters.
I also tried your data and did not arrive at the solution you gave.
(It did come out to the same magnitude though; ie 10^14 Hz).
You may want to double check and see if your given data is correct.
If so, then the expected solution you gave is very likely, incorrect.
May6-05, 01:56 AM   #5
Recognitions:
Quote by Ouabache
Quote by bross7
λ = d*y/(m*L)
f = c/λ
The textbook's answer is CORRECT. Remember that the "2nd Order Minimum" occurs at m=(1.5). Using that value will result in the given answer.
Thread Closed
Similar discussions for: Light/Diffraction/Refraction
Thread Forum Replies
Diffraction, refraction & reflection General Physics 12
diffraction vs refraction General Physics 15
light transmission, reflexion, refraction and diffraction at a atomic level General Physics 5
refraction vs. diffraction General Physics 1
Reflection,Refraction,Total Internal Reflection,Diffraction Introductory Physics Homework 2
