What Depth Achieves Sixfold Atmospheric Pressure in a Lake?
To determine the depth at which the absolute pressure in a lake is six times the atmospheric pressure of 1.01 x 105 Pa, the correct formula is P = ρgh. The calculation shows that at a depth of 7.17 meters, the absolute pressure reaches this level. The density of water is approximated as 1000 kg/m3 for the calculation, and the acceleration due to gravity is taken as 9.8 m/s2. The initial approach mistakenly calculated the change in pressure instead of the total pressure at that depth.
  • Understanding of fluid mechanics principles
  • Knowledge of pressure calculations in fluids
  • Familiarity with the formula P = ρgh
  • Basic algebra for solving equations
  • Study the effects of pressure on fluid density
  • Learn about hydrostatic pressure and its applications
  • Explore variations in water density with depth
  • Investigate real-world applications of pressure calculations in engineering
Students in physics or engineering, professionals in fluid dynamics, and anyone interested in understanding pressure dynamics in aquatic environments will benefit from this discussion.
cavery4
At what depth beneath the surface of a lake is the absolute pressure 6 times the atmospheric pressure of 1.01 x 105 Pa that acts on the lake's surface?
pressure = density * g * h
I thought to multiply 6 * 1.10 X 10^5 pa. Then divide that answer by 1000 kg/m3 (density of water, right?) * 9.8 m/s/s.
This was marked wrong my webassign.
Can someone help me figure out what I did wrongly?
Thank you.
You were almost right, but you calculated the depth at which the change in pressure was six times the surface pressure. This makes the total pressure at that depth slightly more than six times the surface value.
[tex]h\ =\ depth[/tex]
[tex]P-P_s=\Delta P=\rho gh[/tex]
[tex]\frac{P+\Delta P}{P}=6=1+\frac{\rho gh}{P}[/tex]
[tex]h=\frac{5P}{\rho g}[/tex]
Just a little smaller than your value. :smile:
To find the depth at which the absolute pressure is 6 times the atmospheric pressure, we can use the formula for pressure: P = ρgh, where P is pressure, ρ is density, g is acceleration due to gravity, and h is the depth. We know that the atmospheric pressure acting on the surface of the lake is 1.01 x 10^5 Pa. So, to find the depth at which the absolute pressure is 6 times this atmospheric pressure, we can set up the equation:
6 * 1.01 x 10^5 Pa = ρ * 9.8 m/s^2 * h
Now, we need to find the density of water at the given depth. The density of water changes with depth due to the increasing pressure, so we cannot simply use the density of water at the surface. Instead, we can use the fact that the density of water at a depth of 1 meter is approximately 1000 kg/m^3. This means that at a depth of h meters, the density of water would be approximately 1000 kg/m^3 * h. Substituting this into our equation, we get:
6 * 1.01 x 10^5 Pa = 1000 kg/m^3 * h * 9.8 m/s^2 * h
Simplifying, we get:
6.06 x 10^5 Pa = 9800 kg/m^3 * h^2
Solving for h, we get:
h = √(6.06 x 10^5 Pa / 9800 kg/m^3) = 7.17 meters
Therefore, at a depth of 7.17 meters below the surface of the lake, the absolute pressure would be 6 times the atmospheric pressure. It seems like you may have made a calculation error in your answer, which is why it was marked wrong. I hope this explanation helps you understand the correct way to solve this problem.
11K
9K
