Electrical question (well, lightning, really)
The discussion revolves around the behavior of lightning, particularly whether it can be directed upwards and how conductive materials, such as metal, influence its path. Participants explore theoretical scenarios involving devices that could emit lightning and the implications of having metal on one's person during such events.
  • One participant questions if lightning can shoot upwards and whether it would be attracted to metal objects on a person.
  • Another participant explains that lightning typically travels from the ground to the sky and is attracted to conductive objects, likening it to a capacitor's function.
  • A participant expresses confusion about the previous explanations and seeks clarification on the interaction between a device that shoots lightning and metal objects.
  • One participant introduces the concept of a plasmatic track created by lightning, suggesting that once established, the path cannot change until the energy is discharged.
  • Another participant discusses the path of least resistance, explaining that lightning is likely to strike conductive objects that are pointed upward and grounded, such as lightning rods, and shares insights from a related experiment on metal piercings and lightning strikes.
  • The same participant warns about the dangers of being in an open field during a thunderstorm, emphasizing that a person's height can increase their risk of being struck.
Participants express various viewpoints on the behavior of lightning and its interaction with conductive materials. There is no consensus on the specifics of how lightning would behave in the proposed scenarios, and some participants seek further clarification on the concepts discussed.
Participants' statements reflect a range of assumptions about the nature of lightning, conductivity, and the effects of environmental factors, which remain unresolved in the discussion.
DeeZee
Can lightning shoot up? Say someone had a device that could fire out lightning, would it shoot upwards or would it come down?
Oh! And if the person had mechanical devices on them, like metal or something, would the lightning be attracted to it?
Lightning goes from the ground to the sky. Lightning is the relay of excess charge between two conductive mediums, such as in any simple capacitor. The only difference is light travels through air, which has a dielectric constant greater than one. It would be attracted to any conductive object, just as any spark or electron "jumping the gap".
So...If a person was using a device or something to shoot lightning up, it would go up, but if they had something on them like metal or a device made of metal, it would go right to that instead? Sorry, I just don't understand all of what you're saying exactly. :|
This is not so simple
The lightning "travels" via a plasmatic "track", which is created by the lightning itself.
This is like with machine that lays the railroad tracks and advances by riding on the last layed railroad tracks and so on...
Once the plasmatic track was defined (the lightning reached the final destignation, the track path can't change and the lightning continue with the same path until the energy discharged...
Think of path of least resistance - since air is such a poor conductor anything that assists in letting it travel less distance across this poor conductor is the likely spot of origination. That's why things like power line poles, trees, buildings, et cetera are the likely place for it to strike and where lightning rods are located to help divert it around the structure. Not only are they made of metal, they are pointed upward and grounded electrically to assist in their probability of being the place struck.
On the TV show "Mythbusters" they did a test to see if having a metal tongue piercing increased the chance of being struck by lightning and found no real statistical rationale for it. Our bodies are made up of a lot of water and traces of salt and other minerals are in the blood - we're not very perfect insulators and can conduct pretty well at the voltage levels of lightning.
If you are standing in the middle of an open field in a thunderstorm this is very dangerous. Your head is now 5-6ft closer to the clouds making you the path of least resistance. And like the first 2 guys who tried to repeat Franklin's kite experiment and actually ended up with lightning found out, its not a good thing. A set of metal keys in your pocket is not a big concern, getting yourself low to the ground (to avoid becoming a lightning rod) and moving away from a lone tree that is likely to be struck and so on should be the primary concern.
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 44 ·
