Calculating Bouyant Force & Volume of Water for Cardboard Boat
The discussion revolves around calculating the buoyant force and volume of water displaced by a cardboard boat, as well as determining the water level on the boat. The subject area includes principles of buoyancy and fluid mechanics.
  • Participants discuss Archimede's principle and the conditions for equilibrium of the boat. There are inquiries about the specific data needed for calculations and the equations required to solve the problems presented.
Some participants have offered general principles and guidance on how to approach the calculations, while others express a need for specific equations. The discussion reflects a mix of attempts to clarify the problem and explore the necessary calculations without reaching a consensus on the solutions.
Participants note the lack of detailed information regarding measurements and previous work done on the project, which may affect the ability to provide specific guidance. There is also mention of imposed homework constraints related to the project requirements.
aznboi986
I need to calculate the buoyant force of a cardboard boat and the buoyant force exerted by the water. What is the equation to do this?
Also, I need to the volume of water the boat displaces. (Density of water is 1000 kg/m^3).
And last but not least, I need to determine the water level on the boat.
If anyone could help me out with the equations, that'd be great. Thanks.
Since you didn't state the problem in sufficient detail to get an answer, nor did you show what you've done so far, all I can offer are some generalities:
(1) Archimede's principle tells us that the buoyant force on a submerged object equals the weight of the displaced fluid (in this case water).
(2) If the boat is floating, then it must be in equilibrium: the vertical forces must balance. (What forces act on the boat?)​
Sorry. We had to do a project, and make a boat out of cardboard and tape, and 2 people had to get in and paddle across a pool. Now for my lab writeup, I have to answer 3 problems, but we did bouyancy so long ago, I forgot/lost my bouyanct equations (my bad, should have saved them).
1st question. Calculate the buoyant force exerted by the water on the boat for the following conditions 1) empty boat. 2) boat with occupants in
2nd question. FOr each of the aboce conditions in calculation 1, calculate the volume of water that the boat must displace. Use a density of water of 1000 kg/m^3
3rd question. For each of the above conditions and using your plans for your boat design, determine the water level on your boat.
All I need are the equations and I can plug in the numbers. Thanks.
I wonder what data you recorded.
Assuming you measured the weight of the boat + occupants, use point #2 in my last post to answer this one.
For this one, consider point #1 in my last post. Also make use of the definition of density: D = mass/volume.
The volume of water displaced combined with the geometry of your boat should allow you to answer this one.
I appreciate your help, but I need the equations...badly...please
Nevermind, I found the equations. Thanks though.
