Two Questions about my Microwave Oven
  • Context: Graduate
  • Thread starter Thread starter The Rev
    Microwave oven
The discussion revolves around the functioning of microwave ovens, specifically focusing on the principles of microwave radiation, its interaction with water molecules, and the mechanisms that prevent microwave photons from escaping the oven. Participants explore both theoretical and practical aspects of microwave technology.
  • Some participants suggest that microwave ovens operate by using electromagnetic waves to agitate water molecules, producing heat through photon-electron interactions, while others clarify that microwaves primarily excite rotational energy states rather than electronic transitions.
  • There is a discussion about whether observing the cooking process affects the state of the food, with some participants questioning the application of quantum mechanics to macroscopic systems.
  • Participants debate how microwave frequency photons are contained within the oven, with explanations involving the design of the microwave door and the nature of standing waves in the cavity.
  • One participant mentions that microwaves do not pass through gratings smaller than their wavelength, which is relevant to the design of microwave ovens.
  • Concerns are raised about the potential for microwave leaks if the oven's screen or door is damaged, emphasizing the importance of the microwave seal.
  • Some participants express skepticism about claims regarding the dangerous potential of microwave ovens when misused, referencing urban legends and anecdotal evidence.
Participants express multiple competing views on the mechanisms of microwave heating and the implications of quantum mechanics in this context. The discussion remains unresolved on several points, particularly regarding the nature of photon interactions and the implications of observation during cooking.
Limitations include varying levels of understanding of quantum mechanics among participants, differing interpretations of how microwaves interact with matter, and the potential for miscommunication regarding safety and functionality of microwave ovens.
The Rev
These are probably the newbest of newb questions, possessing of a level of ignorance that moves right past funny into sad...however, being the curious type that I am, I'm going to tempt the cat's proverbial fate, and ask anyway.
1) My understanding is that microwave ovens work on the principle that EM waves of a certain frequency (microwaves) agitate the water molecules in the food, and as a result of the agitation, heat is produced which then cooks your food. Now, what I don't know about quantum mechanics is a lot, but doesn't this basically come down to photon-electron interactions, where the photons are of just the right frequency to cause the electrons to change state within the hydrogen and oxygen atoms in water?
If this is so, then nuking food is basically a quantum interaction, right?
Well, if this is so, then one might assume that the food is in a superposition of states until observed, at which time a state of "cooked" or "uncooked" is determined by the collapse of the microwave energy's wave function.
What happens if you watch the food the entire time it's "cooking"? How can the food change states if it's being observed the entire time?
2) How do they keep the microwave frequency photons from escaping the oven if visible light can get out?
Thank you for indulging me.
[tex]\hbar[/tex]
The Rev
1. Why don't you just regard the microwave as a very quick changing E field... The water molecule is just a electric dipole flipping in the changing E field... Does that solve your problem?
2. How do they keep the microwave frequency photons from escaping the oven if visible light can get out?
If you look at the microwave (oven) glass door carefully, you will see ______. That is the reason microwave cannot pass through... (please go to your microwave oven and tell me what you see)
Like I said, I don't know THAT much about QM, so my answer is, "Maybe." If I understood your answer, I might be able to collapse that Maybe Function into a Yes or No.
Alright, smarty, yes, I have seen the little screen. What makes it keep in the microwave frequency photons, but pass the shorter wavelength visible light?
[tex]:)[/tex]
The Rev
1. Microwave photons interacting with a water molecule are not electronic interactions per se, as they do not excite electrons into higher orbitals etc. Microwaves are only able to excite electrons into higher rotational energy states. Microwave energy absorbed by the water molecules will manifest as additional rotational and translational energy, which we identify on a macroscopic level as heat.
As soon as you involve large numbers of photons and molecules (around 10^20 to 10^24 for both in this case), classical physics is quite sufficient to describe the processes that occur in a microwave. Trying to apply quantum principles to macroscopic fields and objects is inappropriate.
2. Microwaves establish a standing wave between two paralled metal plates. The field in this case is actually very well confined for this reason, and does not rely on the absorptive properties of the microwave's outer casing to prevent the microwave radiation from escaping. Visible light is able to enter/exit the microwave due to the plastic window being transparent throughout most of the optical spectrum.
Claude.
Waves will effectively not pass through a grating that has a smaller resolution than the wavelength of the wave (This works in water as well). Microwaves are in the centimeter band, and will not pass through a grill smaller than that.
Radio telescopes are even more coarse: little more than a wire mesh - you can stick your fingers through them! (But they are opaque to radio.)
Claude.
This is where I was mistaken. I thought the electrons were being excited into higher orbitals. I've only read Gribbin's two books, and while they stimulate ideas, they aren't exactly comprehensive texts. I need to get Quantum Mechanics in Exhaustive Detail for Dummies. :smile:
That's really cool.
[tex]\phi[/tex]
Firstly, the microwaves may establish standing waves within the cavity, but if you do not have a good screen, the microwaves will leak out easily. If the screen is damaged you can get microwave leaks. If the door is damaged you can get leaks. There is a potential produced on the screen of your microwave door and it needs to be grounded. I hope no posts in this thread will be taken to suggest that the microwave seal of the enclosure is not of great importance.
Secondly, there is a general misunderstanding with how microwaves heat food. Water vapor has a rotational energy mode right around the frequency microwave ovens operate at, and many think this is the operation that generates heat in the water. It isn't. Water molecules in liquid form do not have quantised rotational modes, and suggesting it is the alternating rotation of the molecules isn't the full story. Most of the heat has to do with electrical currents created in the material and the heat is generated by the material's resistance. This heating operation has been studied by chemists interested in using it.
A time ago i found in the net, an article that explained how to build a weapon out of a microwave oven...
it said that a 2000w magnetron pointed at a human for 5sec could kill..
I still had my doubts...
It would certainly blind them and cause permanent damage to parts of their brain.
But uh... it's going to have to be plugged in. It's hard to focus radiation of that wavelength, so it will be very heavy. It's going to have a very short range.
Just hit em with a baseball bat instead.
I don't know if this is urban legend or not, but I heard the story of a technician repairing an F-16 combat radar while someone was inadvertedly standing in front of the airplane, and the person was reported to feel dizzy without a reason. I think these radars are also in the KW range (but in pulsed mode).
cheers,
Patrick.
  • · Replies 30 ·
17K
  • · Replies 58 ·
  • · Replies 19 ·
