How to find r in the equation P(5,r)=20
  • Thread starter Thread starter MiniTank
The discussion revolves around solving for the variable r in the equation P(5, r) = 20, which pertains to permutations. Participants explore algebraic techniques to isolate r, while also discussing a related problem involving seating arrangements of individuals from different nationalities at a conference.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to manipulate the equation using factorials and expresses uncertainty about the next steps after deriving an equation involving (5-r)!. Other participants suggest expressing numbers as factorials and consider the implications of factorial definitions. The discussion shifts to a new problem regarding seating arrangements, where participants share their reasoning and calculations, questioning the correctness of their approaches.
Participants are actively engaging with the problems, offering hints and suggestions without reaching a consensus on the final answers. Some guidance has been provided regarding the manipulation of factorials and the interpretation of the seating arrangement problem, but no definitive solutions have been established.
Participants are navigating through algebraic manipulations and factorial concepts, with some expressing uncertainty about their calculations. The transition to the seating arrangement problem introduces additional complexity, with varying interpretations of the arrangement rules.
MiniTank
how would you solve for r in this situation:
P(5, r) = 20
Now I understand you can't use trial and error to find that r=2 but is there any other way using an algebraic technique. Itried something like this..
[tex]\frac{5!}{(5-r)!}=20[/tex]
then
[tex]\frac{5\times4\times3\times2\times1}{20}=(5-r)![/tex]
[tex]6=(5-r)![/tex]
now i don't know what to do next
Express 6 as a factorial.
And consider what [tex](5-r)![/tex] means.
[tex](5-r)! = (5-r)*(5-r-1)*(5-r-2)[/tex] etc...
That with whozum's help should help you see the cancellation (hint).
ahh i see then you get 3!=(5-r)!, then cancel out the factorials and you get 3=5-r.. solve for r .. r=2 .. thanks, that's been bothering me a lot
i got another question but I am not sure if it has to do with permutations or but it has a similar subject. should i post it in this topic?
Go ahead. Also I didnt check your work on the first one, but if all is correct til the last step then r = 2.
3 Canadians, 4 Americans, and 2 Mexicans attend a trade conference.
a) In how many ways can they be sated in a row if people of the same nationality are to be seated next to each other?
b) redo (a) if they sit at a round table
for a) the way i look at it is for the Canadians there are three ways which they can be seated so you get 3!, then same for the americans and mexicans getting 4! and 2! respectively. Then you have a total of three nationalities which means they can be switched around giving you 3!.. Therefore in total you get
3!(3!+4!+2!)
=3!(32)
=192
not sure if that's right
b)im pretty sure this is wrong but here's what I am thinking
[tex]\frac{8!}{3!4!2!}<br /> =4\times7\times5<br /> =140[/tex]
any takers?
k scratch what i did for (b) i just figured out that's wrong.. assuming what i did in (a) was right, then (b) should be something like
[tex]1\bullet2!(1\bullet2!+1\bullet3! +1\bullet1!)[/tex]
[tex]=2(9) = 18[/tex]
3!(3!+4!+2!)
=3!(32)
=192
SOLUTION HINTS:
{# in C Block} = 3
{# in A Block} = 4
{# in M Block} = 2
a)
There are (3!) arrangements of the 3 Block Units. For each Block Unit arrangement, there are (3!) sub-arrangements within the "C" Block, (4!) sub-arrangements within the "A" Block, and (2!) sub-arrangements within the "M" Block.
{Total Arrangements} = (3!)*{(3!)*(4!)*(2!)}
b)
The round table has 9 chairs. Let the chair closest to North direction be designated "N". Chair "N" will be occupied by a member of EITHER "C", "A", or "M". If it's "C", there are 3 possible Block positions relative to "N" (0 members right of "N", 1 member right of "N", & 2 members right of "N"). For each relative position, there are (3!) sub-arrangements. Further, the 2 remaining Blocks ("A" & "M") have 2 possible relative positions (to left of "N" or to right of "N"), with (4!) sub-arrangements within "A" Block and (2!) sub-arrangements within "M" Block. Thus, total arrangements possible when "C" Block occupies chair "N" is:
{(3)*(3!)}*(2)*{(4!)*(2!)} ::: <--- "C" occupies "N"
Calculate similar results for cases when Blocks "A" & "M" occupy chair "N", and add all three results together for total number of arrangements:
{(3)*(3!)}*(2)*{(4!)*(2!)} + ? + ?
xanthym said:
SOLUTION HINTS:
{# in C Block} = 3
{# in A Block} = 4
{# in M Block} = 2
a)
b)
so for b) you get
[3(3!)][2(4!2!)] + [2(2!)][2(3!4!] + [4(4!)][2(3!2!)]
=5184
Alright thanks
18K
