Register to reply
Reference state of some solid
by M. next
Tags: reference, solid, state
Share this thread:
M. next
#1
Mar23-14, 05:08 AM
P: 378
Supposing that some solid can exist at 2 different phases (had 2 different crystalline structure) at some temperature and pressure. Can we define the same reference entropy or chemical potential for these two states (knowing that we are talking about the same solid)?
Phys.Org News Partner Physics news on Phys.org
Interfaces within materials can be patterned as a means of controlling the properties of composites
A new, tunable device for spintronics
Researchers study gallium to design adjustable electronic components
M Quack
#2
Mar23-14, 07:34 AM
P: 669
There are indeed materials that can have different crystal structures under the same conditions. For example titanium dioxide, TiO2, can be found in the rutile, anatase or brookite crystal structure at room temperature and pressure (Rutile seems to be the equilibrium state, anatase and brookite are metastable). However, the entropies and chemical potentials of the different structures will almost certainly differ by a small percentage.
http://en.wikipedia.org/wiki/Titanium_dioxide
The "reference phase" in this case should clearly be rutile, as it is the equilibrium phase.
M. next
#3
Mar23-14, 08:53 AM
P: 378
Thank you for your reply.
So you are saying by a small percentage. Ideally speaking, can I take them the same and neglect this "small" percentage?
And one more thing, why do they differ by a small percentage and not a large one?
M Quack
#4
Mar23-14, 09:35 AM
P: 669
This is a bit hand-waving, but if the difference was very large, then the higher (free) energy phase would probably not be meta-stable.
I have no idea how large exactly the differences are, but to first approximation it can probably be neglected in most cases.
A counter-example might be carbon, which can occur as graphite or diamond. Their properties are quite different...
M. next
#5
Mar23-14, 10:03 AM
P: 378
Oh to neglect the difference, the higher energy phase must be meta stable?
M Quack
#6
Mar23-14, 03:34 PM
P: 669
I guess the definition of meta stable is "has higher energy than the ground state, but has an energy barrier to overcome to get there". Because of the energy barrier the state can "survive" for some time.
If the higher energy state was not meta stable it would be unstable and decay to the ground state.
The idea is that there is only one ground state phase, therefore all others that can exist under the same conditions must be meta stable, i.e. the ground state under different conditions, but that does not spontaneously transform to the ground state when the conditions are changed. Diamond is a good example.
To neglect the differences the two phases must be sufficiently similar. For the different forms of TiO2 that
may be a good approximation. For Graphite/Diamond I am not so sure.
(you may have noticed that I am moving from waving my hands to flailing my arms :))
Other examples are undercooled liquids that remain liquid even below the nominal freezing point. This can be generalized to all first order phase transition that show some hysteresis.
DrDu
#7
Mar23-14, 04:31 PM
Sci Advisor
P: 3,595
Quote Quote by M. next View Post
Of course there is a phase transition line between different crystalline phases where two different phases coexist.
They have the same chemical potential as they are in equilibrium with respect to particle exchange.
An example is the equilibrium between rhombic and monoclinic sulfur.
Register to reply
Related Discussions
Could there be an absolute 'state of reference?' Special & General Relativity 135
What is a Standard State or Reference State of an element? Chemistry 2
Reference for Ice-Solid Interfacial Tension General Engineering 0
Specify the reference state for potential energy? Introductory Physics Homework 17
Solid state physics: phonon density of state Advanced Physics Homework 0
