Register to reply
Smallest Body Possible to Have Rings
by 3point14rat
Tags: body, rings, smallest
Share this thread:
3point14rat
#1
Mar28-14, 02:15 PM
P: 3
What is the lower mass limit for a body to have rings?
I'm thinking that Chariklo, at 155 miles in diameter is pretty small. Gravity would be so weak you'd have to hold on just to not 'jump' off with every step.
Cheers,
3point14rat
Phys.Org News Partner Astronomy news on Phys.org
Comet Jacques makes a 'questionable' appearance
Image: Our flocculent neighbour, the spiral galaxy M33
Image: Chandra's view of the Tycho Supernova remnant
Simon Bridge
#2
Mar28-14, 10:30 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,463
Welcome to PF;
To figure that out you need to know the conditions required for rings to form.
What are they?
http://wordpress.mrreid.org/2013/04/...anetary-rings/
D English
#3
Mar29-14, 07:56 AM
P: 33
Awesome link Simon, very easy to understand. Thank you.
3point14rat
#4
Mar31-14, 10:02 AM
P: 3
So, there is no minimum size an object can have, below which it cannot support rings? The Roche Limit sounds like it's the closest an object can orbit without breaking up, not the minimum size the primary object must be to have the gravity necessary to support rings.
I'm asking because the discovery of Centaur Chariklo doesn't seem to have raised much skepticism over the fact that such a tiny object has rings. I'm just a guy who read an article on it and immediately thought that there's no way something that small could hold onto anything, let alone a couple of rings.
Is my ignorance showing?
mfb
#5
Mar31-14, 12:47 PM
Mentor
P: 11,589
"Support" is always a matter of time for rings, but there is no fundamental limit that says "this object is too small, it cannot have a ring".
Right - as long as internal stiffness of the objects is negligible. This is a good assumptions for large objects, it can be wrong for small objects.
You can make two billard balls orbit each other in space if you like. Why not? They just have to move very slowly (and don't be too close to other massive objects).
Simon Bridge
#6
Mar31-14, 08:32 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,463
What he said.
I'd add that the radius of the small object may be a limiting factor.
Though I haven't done the math for a body whose radius is bigger than it's Roche limit.
When you hear "rings" you tend to think "Saturn" ... but there is no need for rings to be so spectacular or even visible. Rings are generally be difficult to detect unless very big and/or they have lots of ice in them.
These ones were detected by stellar occultation with spectrographic data in support.
There's a decent reference:
http://www.nature.com/nature/journal...ture13155.html
... there's plenty there but the bulk is (sadly) behind a paywall.
Phil Plait (aka Bad Astronomy) has a nice discussion on the findings:
http://www.slate.com/blogs/bad_astro...ve_a_ring.html
But basically you have not seen skepticism concerning rings about such a small object because it is scientifically plausible with well known mechanisms. The main iffy bit is that there are two well-defined rings and Phil talks about that (link above).
3point14rat
#7
Apr1-14, 11:15 AM
P: 3
I read Phil's article and the data really does demonstrate rings. That's awesome.
I'm still very suprised that there are rings on such a small object and that it may even have a tiny moon that's herding the rings. These situations must have a very limited life span, so we're very fortunate to be around when it's discovered.
So glad I came on here to see what smart people had to say on the subject. Thanks a heap
Cheers,
3point14rat
LURCH
#8
Apr1-14, 02:40 PM
Sci Advisor
P: 2,510
Last I heard, astronomers were still looking for the mechanism by which these rings might have been formed. This centaur's gravity is too weak for the usual method of tidal forces tearing a satellite apart. I have been thinking that this centaur orbits at a distance from the Sun at which ice (water ice) does not sublimate. But what about ammonia or methane or CO2?
mfb
#9
Apr1-14, 05:57 PM
Mentor
P: 11,589
Quote Quote by Simon Bridge View Post
What he said.
This just depends on the density ratio, as
$$d = 1.26\; R\left( \frac {\rho_M} {\rho_m} \right)^{\frac{1}{3}}$$
where d is the Roche limit and R is the radius of the primary object and the densities are the averages over the whole objects. Roche limit and radius scale in the same way.
Register to reply
Related Discussions
Machine accuracy vs. smallest representable number vs. smallest normalized number Engineering, Comp Sci, & Technology Homework 0
Comparing definitions of groups, rings, modules, monoid rings Linear & Abstract Algebra 1
Sigma-rings are closed under countable intersections (sigma-rings are delta-rings) Calculus & Beyond Homework 2
Smallest known 2 body system Astronomy & Astrophysics 2
Measure (rings and algebras) question: smallest ring containing a set Calculus & Beyond Homework 3
