Register to reply
Cantilever beam with curved beam on the end.
by KESTRELx
Tags: beam, cantilever, curved
Share this thread:
KESTRELx
#1
Mar29-14, 12:03 PM
P: 6
struggling to find info on this so figgured i'd as.
For two beams attached to each other, one a straight catilever and the second a 90 degree bent beam attached to the end of the cantilever (shown in attached picture). To calculate the deflection of the beam at the load applied, given the load applied is on the open face of the bend.
Would you concider each part seperatly?
so for the curved beam calculate the bending moment applied to that relative to the assumption that the straight part of the beam is fixed in position, then calculate its displacement.
Then apply the same bending moment to the canilever calculate its displacment.
To get the total displacement add the compenents of the cantilever and the bend together to get its final position?
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
paisiello2
#2
Mar29-14, 08:28 PM
P: 558
That would not give you the right answer because the straight portion of the cantilever also rotates at its tip causing an additional rotation and deflection of the curved portion.
Register to reply
Related Discussions
Cantilever beam Engineering, Comp Sci, & Technology Homework 3
Cantilever Beam Engineering, Comp Sci, & Technology Homework 1
Beam deflection in a cantilever beam Mechanical Engineering 3
Cantilever beam Engineering, Comp Sci, & Technology Homework 1
Cantilever beam Engineering, Comp Sci, & Technology Homework 7
