Register to reply
Materials that change thermal properties by applying electrical input?
Share this thread:
material
#1
Mar30-14, 05:58 PM
P: 14
Do such materials exist? If they do, are there materials that go from very high to very low thermal conductivity depending on electrical input?
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
christopher.s
#2
Apr11-14, 10:01 PM
P: 17
A heat switch can be made with superconductors at low temperature. A metallic superconductor below its critical temperature will not conduct heat very well because of electron pairing, while above the critical temperature (normal state) it will conduct heat very well. This metal is used as a heat transfer channel, while another superconductor in close proximity generates a magnetic field from a bias current. This magnetic field will force the heat channel to toggle between its normal and superconducting state. The ratio varies between on/off conductance varies but can be as high as 1000x.
Register to reply
Related Discussions
Some materials properties Introductory Physics Homework 3
Thermal properties of materials Introductory Physics Homework 1
Mechanical properties of materials. Engineering, Comp Sci, & Technology Homework 16
Electrical and Computer Engineering, 2-input Look-Up tables designed with 2-input XOR Engineering, Comp Sci, & Technology Homework 0
Thermal properties of materials,please ! Introductory Physics Homework 0
