Crossing Over: Exchange of Nucleotides & Genes
  • Thread starter Thread starter STAii
The discussion centers on the biological process of crossing over during meiosis, specifically the exchange of nucleotides and genes between chromatids. Participants explore the implications of partial gene exchanges and the conditions under which these occur, touching on concepts of genetic recombination and the potential consequences for gene functionality.
  • Some participants explain that crossing over involves the exchange of entire arms of chromosomes, not just individual nucleotides.
  • Others propose that it is possible for only parts of genes to be exchanged during crossing over, raising questions about the functionality of the resulting genes.
  • One participant mentions that recombination occurs at homologous sequence sites, which can lead to functional or non-functional genes depending on the nature of the sequences exchanged.
  • There is a discussion about the concept of cross-over interference, which inhibits recombination at the same location on the chromosome.
  • Some participants express uncertainty about how new gene sequences resulting from crossing over can maintain meaning or functionality.
  • Examples are provided to illustrate how crossing over can occur without disrupting the open reading frame of genes, suggesting that as long as the coding sequence remains intact, the resulting genes may still function properly.
Participants do not reach a consensus on whether partial gene exchanges can occur without causing problems. While some agree that it is theoretically possible, others question the implications for gene functionality and express uncertainty about the outcomes of such exchanges.
Limitations in the discussion include the lack of clarity on the specific conditions under which partial gene exchanges might occur and the assumptions about sequence homology required for successful recombination.
This discussion may be of interest to those studying genetics, molecular biology, or anyone curious about the mechanisms of genetic recombination and its implications for gene function.
STAii
Hello.
I have a little question about 'crossing over'.
Sorry for the scientifical terms, i was unable to find all of them, so i guess this will be hard to understand (i would appreciate if you correct me in spelling, and give me the scientifical terms that i missed).
I understand tha during crossing over, part of the non-identical chromatides forming a tetrad are exchanged.
I also know that the chromatides are made of a DNA molecule (and ... proteins ?), which are made of neucluotides, and that a gene is a group of codons, being 3 neucuotides.
So, in conclusion, during 'Crossing over', some neucluotides are exchanged.
Now, my question is, is it possible that not a whole gene gets exchanged between the two chromatides (iow, half a gene, or quarter a gene). If so, wouldn't this cause a lot of problems ?
Thanks (if you see the question is not clear enough, please ask me to clear it :smile: ).
Biology news on Phys.org
Yes this can happen because recombination occurs at homologus sequence sites. It does not create problem if both the first half is complementary to the second half. Meaning that the gene will not become non-functional. It can cause problem when recombiantion occurs at not some homologous sites (i.e. 2 similar sequence but not complementary to each other). Then a gene and also a chromosome can become non-functional.
Also recombination also used to introduce mutation in genetic enginerring. And recombination can also occurs at specific sites and site specific recombination requires special enzyme, which are called recombinase.
some definition
Chromatid: a portion or strand of chromatin
Chromatin: The chromosome as it appears in its condensed state, composed of DNA and associated proteins (mainly histones).
Hi Staii, crossing over occurs during meiosis, the forming of gametes. At this time the two same chromosome pairs are alligned (say twice chr. 19) to be separated from each other to form a haploid cell.
Here is a good image of what happens: http://www.uni-kiel.de/medinfo/mitarbeiter/krawczak/folien/vorlesung9/img004.jpg
So yes, a chromatid is a single strand of a DNA molecule, the upper portion of the image is the tetrad. You should understand this is a dynamic structure! The tetrad is not fixed at a point in the strand, but can move up and down like a zipper.
So, on the DNA there are genes. A gene consists of coding and non-coding regions. The coding regions have a three-letter code: codons, which will become a certain aminoacid during translation.
But then you go wrong, nucleotides are not exchanged, an entire arm of the chromosome is exchanged! So this is something which happens at a single point, as is clear in the image.
So it could be that half the gene is paternal and the other half of the gene is maternal, yes. But then you ask if it is possible to get a quarter gene. This is actually a very good question.
As you can see, a single cross over (recombination event) results in half blue, half red. Now, during meiosis about 40 of these cross-overs occur. So an alternating pattern of blue/red is possible. The distances are restricted though!
I forgot what it is called, it has a special name. Basically, if a cross-over has happened somewhere on the genome, it is highly unlikely - if not impossible - for a second crossover to occur in the same fecinity.
Problems don't occur, as long as the cross over is symmetric.
Ian has beaten me :)
Just to make it clear, during meiosis there is a process that inhibits recombination happening near the same spot twice.
Genetic engineering though IS possible, where such homologous recombination exchanges a very specific piece of DNA.. but there are also length restriction, I am not aware how long since I never actually did the experiment :)
You are right, i mis-expressed.
What do you mean ?
Ok, back the subject.
I am not suggesting that the process happens twice.
Let's go back to your drawing.
In your drawing, the genes that the drawing was focusing on where not in the exact point of the chiasma (A,a,B,b are all not in the point of chiasma).
Now, suppose that A (for example) was at the exact point of chiasma, a certain percentage of it was on the right side of the chiasma, and another part was on the left part of the chiasma.
This way, only part of the gene A will be transported from one chromatid to another.
This is what i am talking about, is this possible ?
I remember now! It is called cross-over interference.
Yes, that is what I meant :)
You have got two Chr. 19, one from your father, one came from your mother. These two allign. Cross over occurs in the middle of the gene. Now that gene on the chromosome consists part of the paternal and part of the maternal DNA (ofcourse the DNA is all yours, but it makes the discussion clearer as to the origins of the DNA).
Umm .. weird.
Now, the gene is a sequence of neucluotides.
If two different sequences (ie, two genes) where exchanged from the middle, how do we know that the result actually has any meaning ?
Suppose (for example) that a gene is :
AAATTGGCC <-- from father
GCCTAGCCT <-- from mother
.. Crossing over after the forth neucluotide ...
AAATAGCCT <-- New 1
GCCTTGGCC <-- New 2
The old sequence had a certain meaning (it was a working gene), but how do we know that the new gene has any meaning ?
This image is actually a better representation of the chromosomes:
http://www.mds.qmw.ac.uk/statgen/dcurtis/lectures/meiosis.gif
I am not sure how to interpret your sequence, staii.. let me say this: we share 98% of our DNA with the chimps.. how much is the same between humans? 99.9xx%
Our genes are the same, the alleles make us different from each other. So it doesn't matter if the first half of the gene has a maternal origin and the other half a paternal origin. As long as the cross over is symmetric and the ORF (open reading frame of the codons) is not changed.
From what you say, it seems like any random neucluotides sequence will be meaningfull (and functional) ?
Anyway ...
Can you explain this :
Open reading frame of the codons
Thanks for all the help
(BTW, this seems like a chat more than being on forums)
AAATAGCCT <-- New 1
GCCTTGGCC <-- New 2
Staii, your example will not probably happen because there is not enough homology between both sequence.
Here a better example
AAATATATATAGTGCTATATATTTTTATTTATTATGGTG <-----Father
AAATATATATAGTGCTATATCTTCTTGTTTATTATGGTG <-----Mother
Cross over befor the bold
AAATATATATAGTGCTATATCTTCTTGTTTATTATGGTG <-----New 1
AAATATATATAGTGCTATATATTTTTATTTATTATGGTG <-----New 2
But let's translate the sequence to aminio acid
Lys-Tyr-Ile-Ter-Cys-Tyr-Ile-Phe-Leu-Phe-Ile-Met-Val <-----New 1
Lys-Tyr-Ile-Ter-Cys-Tyr-Ile-Phe-Leu-Phe-Ile-Met-Val <-----New 2
Both a.a sequence are identical. As we said before it will not matter where the cross over occurs unless the ORF is change, the a.a. sequence is change significantly or the cross over occurs at a similar site but not complementary
Example
#19 AAATATATATAGTGCTATATATTTTTATTTATTATGGTG <-----Father
#14 AAATATATATAGTGCTATGGTAGGTAGTAGTAGTTTTATTATGGTG <-----Mother
Double Cross over befor and after the bold
AAATATATATAGTGCTATGGTAGGTAGTAGTAGTTTTATTATGGTG <-----New 1
hehe, you know we will charge you for this :wink:
With ORF the way the codons are read from the site of initiation. It goes in pairs of three right? The following is an ORF of: ACGGTCCCGTTC
ACG GTC CCG TTC in this way it will be translated the wrong ORF would be caused by the insertion of a base for instance:
ACG aGT CCC GTT C
Anyway ...
Why do you say that? The SNP consortium has found 1,255,326 SNPs, Orchid biosciences an additional 10,000.
Btw, it is nucleotide not neucluotide
nice one Ian, but just remember that in vivo things don't happen like that due to cross-over interference.
Yeah but I think we will lose him if it gets too complicated with all the exemption. I tried to keep thing simplified:wink:
Isn't this a coincidence? I noticed that the two original genes are also translated to the same amino acid sequence.
EDIT :
Thanks, i highly appreciate this (and everything else of course), but getting the right terms is always hard when u study in a different language.
This is not a coincidence, I did it on purpose, I change the nucleotides sequence but I kept the same amino acid sequence. It was to show you that the DNA sequence is not that important if the amino acid sequence is the same or relatively the same and the protein is functional.
Yes, but in nature, i don't think that the amino acid sequence will always stay the same (if so, there will be no benefit of 'crossing over')
So, if i am right, the amino acid sequence will actually change, when it changes, what makes the new sequence meaningfull (ie, it will still act like the gene that was in this place before crossing over).
BTW, if you feel you are putting too much effort into this, forget about it.
Thanks.
Yes, but in nature, i don't think that the amino acid sequence will always stay the same (if so, there will be no benefit of 'crossing over') So, if i am right, the amino acid sequence will actually change, when it changes, what makes the new sequence meaningfull (ie, it will still act like the gene that was in this place before crossing over).
Most of the genes do have a amino acid sequence that are identical or similar (meaning that a a.a from a certain group [+ charge, - charege, polar, non-polar and aromatic] is change by another a.a from the same group.
Some genes do have different a.a sequence. For example, a +ve charge a.a is change by a -ve charge a.a. This change migth not affect the function of the protein. In the other hand, the protein could become non-functional or functional under certain conditional (refer to as conditional mutant). Other mutation will introduce a stop codon and the protein becomes non-functional.
Most genes from individuals are not that different but some genes show a lot of different phenotype, eye and skin color for example. Crossing over can be beneficial for individuals that carries dangerous mutation. Crossing over also allow the exchange of gene and a mixture of genes in the population.
Basically you have got two genes, paternal and maternal. These two genes can be completely homologous, than both parents will have blue eyes (hypothetically). Or, the genes have a small difference in the first exon, two alleles. Now the one gene codes for blue eyes and the other for green eyes (hypothetically). Imagine crossing over occurs in the middle of the gene. Since only the first exon is different, and the rest is the same.. only switching of the genotype occurs from paternal to maternal chromosome.
You must understand that genes are highly conserved sequences, there really isn't that much variation in them to cause massive structural changes when they are interchanged.
I have sequenced genes of unrelated individuals, they are completely the same!
Crossing-over DOES have an evolutionary advantage though, a genome is reshuffled, creating more genomic diversity and less inbreeding, simply stated :)
It is also important to keep in mind that only about 2% of the genome is coding, less than 1% exons! (heard that in a lecture, not sure where to get the data from)
A long explantion is that the population of a given specie has a mix of individuals traits and is heterogenous. Therefore when a massive selection pressure (i.e. disease) appears not every individuals are wipe out and the few that are left can rebuilt the population and the specie.
Also recombiantion can also have a bad effect. Non-functional and disfunction (I don't know if it's the rigth term) can be pooled together and pass on.
  • · Replies 18 ·
38K
  • · Replies 16 ·
