Internal stress due to tube bending
The discussion centers on the internal stress changes in a circular steel tube with a diameter of 20mm, thickness of 1mm, and length of 500 meters when bent to a radius of 50mm. The material has entered the plastic stage, necessitating an understanding of the changes in material properties. To accurately calculate these changes, a true stress-strain curve for the steel is essential, along with finite element (FE) analysis to assess strain hardening effects during bending.
  • Understanding of true stress-strain curves for steel
  • Knowledge of finite element analysis (FEA) techniques
  • Familiarity with material properties in the plastic deformation region
  • Basic concepts of nonlinear material behavior
  • Research true stress-strain curve generation for steel materials
  • Learn finite element analysis (FEA) software tools, such as ANSYS or Abaqus
  • Study the effects of strain hardening on material properties
  • Investigate nonlinear material modeling techniques in FEA
Mechanical engineers, materials scientists, and anyone involved in structural analysis or design of bent steel components.
chandran
i have a circular tube of diameter 20mm,thickness 1mm and length 500 metres
i bend the tube into a radius of 50mm. obviously the tube has entered the plastic stage. But what would have happened to the material properties.
hOW CAN I CALCULATE THE CHANGE IN MATERIAL PROPERTIES. THE MATERIAL
OF THE TUBE IS STEEL
Account for the nonlinearities, both types, which were discussed in that other thread. As additional material property information you will need some form of a true stress-strain curve for the tube material in order to accurately compute what is going on in the plastic region. I'd suggest doing a simple FE - analysis of the bending and extracting the amount of strain hardening from the results.
