Register to reply
Special substance (adhesive or paint)
by lawrence
Tags: adhesive, paint, special, substance
Share this thread:
lawrence
#1
Apr2-14, 05:10 PM
P: 2
Hi !
Can you recommend me a glue or paint or other chemical substance with the following properties:
- should be transparent
-should have a refr. index less than 1.6
-could be easily peeled off from glass
- should not dissolve in the same substance after drying (I want to make a thin film, peel it off and then stick it with the same substance to an optical device, but the film should not destroy)
-it is preferably but not mandatory that it should not dissolve in water
Thank you!
Phys.Org News Partner Engineering news on Phys.org
Tiny UAVs and hummingbirds are put to test
Britain to trial driverless cars from 2015
NIST corrosion lab tests suggest need for underground gas tank retrofits
Baluncore
#2
Apr29-14, 03:09 AM
Sci Advisor
Thanks
P: 1,781
Maybe clear epoxy resin. RI = 1.5x
http://www.ntt-at.com/product/hl_resins/
The clear part of a two part epoxy can make a good optical grease.
Baluncore
#3
Apr29-14, 07:47 AM
Sci Advisor
Thanks
P: 1,781
More data;
http://www.eoc-inc.com/optical-coati...capsulants.htm
You may need to use a film or release agent when casting on a glass surface.
Register to reply
Related Discussions
Does exposure to a radioactive substance make another substance radioactive? General Physics 5
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Materials & Chemical Engineering 1
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! General Engineering 6
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Chemistry 1
Adhesive tape Introductory Physics Homework 0
