Register to reply
Strength In Single Crystals
by edcurrymuncher
Tags: crystals, single, strength
Share this thread:
edcurrymuncher
#1
Apr2-14, 06:07 PM
P: 2
Hey, this was the question could someone please help?
"An aluminium single crystal alloy aircraft component is oriented such that a tensile stress is applied along a [102] direction. If slip in this material occurs on a (111) plane
and in a [101] direction, compute the yield stress at which the crystal yields if its critical resolved shear stress is 3.42MPa."
Phys.Org News Partner Engineering news on Phys.org
Greater safety and security at Europe's train stations
Fingerprints for freight items
On the way to a safe and secure smart home
jk60422
#2
Apr4-14, 11:39 AM
P: 1
Suggest you do your own Schmid's law homework.
PS the [101] direction isn't a valid direction in the (111) plane.
jstad
#3
Apr5-14, 08:30 PM
P: 5
I am no authority on the subject but I recently did a problem very similar to the one you're working on. And I believe the poster above me is correct in their assertion. In my problem, the applied load was [120], slip plane (111) and slip direction [110].
Something helpful (which I learned from my professors) is to draw the cubic cell with the indicated plane and directions. This will help you get a feel of what [itex]\phi[/itex] and [itex]\lambda[/itex] look like. In addition to load and slip directions, you will also need to determine the direction perpendicular to the slip plane.
The key, however, is to use the dot product to find cos[itex]\phi[/itex] and cos[itex]\lambda[/itex]. In order to do this you will need to treat the three key directions as vectors.
Hopefully this was of some help to you.
Register to reply
Related Discussions
Interaction of single two level atom with single mode field Quantum Physics 0
Calculation Based on Yield strength and Ultimate strength Mechanical Engineering 4
Isotropic crystals & anisotropic crystals Materials & Chemical Engineering 2
Single Shear Bolt application, strength info required Mechanical Engineering 12
Swapping the values between two registeres in a single step (a single clock cycle) Engineering, Comp Sci, & Technology Homework 0
