Taking Moments About a Point and Resolving Forces
This discussion focuses on resolving forces and calculating moments about a point, particularly in the context of a uniform rectangular lamina and a hinged rod. The key problem involves determining the center of mass for a loaded lamina and calculating the forces acting on a rod at an angle. Essential formulas include the torque equation, τ = rF sin(θ), and the center of mass calculations, xcm = (1/M)Σximi and ycm = (1/M)Σyimi. Understanding these concepts is crucial for solving similar physics problems effectively.
  • Understanding of torque and moment calculations
  • Familiarity with center of mass concepts
  • Basic knowledge of equilibrium conditions in physics
  • Proficiency in trigonometry for resolving forces
  • Study the principles of torque and its applications in mechanics
  • Learn how to calculate the center of mass for various shapes and configurations
  • Explore equilibrium conditions and their implications in static systems
  • Practice resolving forces using free-body diagrams in different scenarios
Students preparing for physics exams, particularly those studying mechanics, as well as educators looking for effective teaching methods in force resolution and moment calculations.
John Matrix
Hi, I have my first year university exam coming up soon and this type of question seems to feature quite prominently in the past paper questions we are given where I have to take moments about a point and also resolve forces horizontally and vertically. I suppose the best way to show you would be with a question and the solution (which we were given by the tutor).
Question:
13(a) A uniform rectangular lamina ABCD is of mass 2m, with AB = DC = 4
cm and BC = AD = 6 cm. Particles, each of mass m, are attached to
the lamina at B, C and D. Calculate the distance of the centre of
mass of the loaded lamina from the sides AB and BC respectively.
Solution:
http://img.villagephotos.com/p/2005-1/929440/PhysicsDiagram1.JPG
http://img.villagephotos.com/p/2005-1/929440/Physicssol(a).JPG
I guess this part involves centre of gravity more than anything but I still don't understand how the moments are taken.
(b) A uniform rod AB, of length 4a and weight W, is hinged smoothly to a
fixed point at A. The rod is held at 60 to the horizontal, with B
above A, by a horizontal force F acting at B. Calculate in terms of W:
http://img.villagephotos.com/p/2005-1/929440/PhysicsHelpDiagram2.JPG
(i) the magnitude of F;
http://img.villagephotos.com/p/2005-1/929440/PhysicsSol(i).JPG
Where do these moments come from exactly? I have a vague idea from the solution and my knowledge of trigonometry but I'm not entirely sure.
(ii) the magnitude of the reaction force at the hinge and its direction to
the horizontal.
http://img.villagephotos.com/p/2005-1/929440/PhysicsSol(ii).JPG
Not sure here how the forces are resolved, a diagram of where the horizontal and vertical forces are in relation to R would really help.
If anyone could show me where these answers are coming from I would be really gratefull since this just doesn't seem to click with me and I have no more classes left to speak with the tutor. Thanks.
The first thing you need to review is how to find the torque (or moment) generated by a force about a point. The torque depends on three things:
the amount of the force, [itex]\vec{F}[/itex]
the point of application of the force measured from the pivot point, [itex]\vec{r}[/itex]
the angle between [itex]\vec{r}[/itex] and [itex]\vec{F}[/itex]​
The magnitude of the torque is given by [itex]r F \sin\theta[/itex].
Regarding 13a:
It may be easier to think of the center of mass as the weighted average position of the mass elements:
[tex]x_{cm} = \frac{1}{M}\Sigma x_i m_i[/tex]
[tex]y_{cm} = \frac{1}{M}\Sigma y_i m_i[/tex]
Regarding 13b:
Start by identifying all the forces acting on the rod. Then apply the conditions for equilibrium: (1) the net horizontal and vertical forces on the rod must add to zero, and (2) the net torque about any point must be zero.
Hints: (a) Treat the force R that the hinge exerts on the rod in terms of its components [itex]R_x[/itex] and [itex]R_y[/itex]. (b) Use the hinge as your pivot point when calculating torques.
Thanks for your help. The solution is a lot clearer now. I'll have a go at some similar questions later and see if I can do them now.
  • · Replies 105 ·
  • · Replies 32 ·
