Specific heat capacity of the final temp
The specific heat capacity of the experimental cup material is calculated to be 0.94 J/g°C. This value indicates that it requires 0.94 joules of energy to raise the temperature of 1 gram of the cup by 1 degree Celsius. The calculation involves using the formula Q = mcΔT, where the heat energy for the water is determined first, followed by substituting values to solve for the cup's specific heat capacity. The initial temperatures of the cup and water were 37.9°C and 21.8°C, respectively, with a final equilibrium temperature of 24.2°C.
  • Understanding of specific heat capacity and its significance
  • Familiarity with the formula Q = mcΔT
  • Basic knowledge of heat transfer principles
  • Ability to perform unit conversions and calculations
  • Research the concept of thermal equilibrium in closed systems
  • Learn about different materials' specific heat capacities
  • Explore advanced heat transfer methods and applications
  • Study the implications of specific heat capacity in real-world scenarios
Students studying thermodynamics, physics enthusiasts, and professionals involved in material science or engineering applications related to heat transfer.
DDV805
Hi, could someone help me get started on this problem, I am having a lot of difficulty comprehending these types of problems. THanks for your help guys.
A cup is made of an experimental material that can hold hot liquids without significantly increasing its own temperature. THe .79 kg cup has an initial temperature of 37.9 C when it is submerged in 1.17 kg of water with an initial temperature of 21.8 C.
What is the cups specific heat capacity if the final temperature is 24.2 C.
To get you started:
1. Think about which way does the heat flow between the cup and water, why there is energy transfer and at what condition there is equilibrium.
2. Assume the system is closed
3. From the given data you can calculate the energy tranferred between the components of the system. From that you can solve for the cups specific heat cap.
Sure, I can help you get started on this problem. First, let's define what specific heat capacity is. Specific heat capacity is the amount of heat energy required to raise the temperature of one unit of mass by one degree Celsius. In this case, we are trying to find the specific heat capacity of the cup, which is a measure of how much heat energy is needed to raise the temperature of the cup by one degree Celsius.
To solve this problem, we can use the formula Q = mcΔT, where Q is the heat energy, m is the mass, c is the specific heat capacity, and ΔT is the change in temperature. We know the mass of the cup is 0.79 kg and the change in temperature is 37.9 C - 24.2 C = 13.7 C. We also know that the cup is not significantly increasing in temperature, so we can assume that its specific heat capacity is very high.
Now, we need to find the heat energy (Q) for the cup. We can do this by using the same formula, but this time we need to use the mass and temperature of the water. The mass of the water is 1.17 kg and the change in temperature is 24.2 C - 21.8 C = 2.4 C. So, the heat energy for the water is Q = (1.17 kg)(4.186 J/gC)(2.4 C) = 9.86 J.
Now, we can substitute the values we know into the original formula and solve for the specific heat capacity of the cup. 9.86 J = (0.79 kg)(c)(13.7 C). Solving for c, we get c = 0.94 J/gC. This means that it takes 0.94 joules of energy to raise the temperature of 1 gram of the cup by 1 degree Celsius.
I hope this helps you understand the problem better and get started on solving it. Remember to always double check your units and make sure they cancel out to give you the correct units for the final answer. Good luck!
  • · Replies 17 ·
