Theory - Why Mass Increases With Velocity
  • Context: Graduate
  • Thread starter Thread starter lavalamp
    Mass Theory Velocity
The discussion revolves around the concept of mass increasing with velocity, particularly in the context of Higgs particles and relativistic effects. Participants explore theoretical implications, the relationship between mass and velocity, and the definitions of mass in physics.
  • One participant proposes that Higgs particles contribute to an increase in mass as particles move faster, suggesting a quantized accumulation of mass due to interactions with Higgs particles.
  • Another participant questions the premise by highlighting that mass does not appear to increase for an observer moving at high velocity, referencing Einstein's theory of relativity which states that all objects observe themselves to have a constant rest mass.
  • It is noted that the increase in mass with velocity is linked to time dilation and length contraction, which are described as interconnected phenomena.
  • Some participants express uncertainty about the definitions of mass, indicating that the debate is ongoing and emotionally charged within the physics community.
  • A participant mentions that mass is invariant and does not increase with velocity, emphasizing that only rest mass can be measured directly.
  • Another participant argues against the notion that mass or rest mass can be directly measured, suggesting that measurements are based on position and time, and discusses the derivation of mass in the context of relativistic equations.
Participants express differing views on the nature of mass and its relationship to velocity. While some agree on the mathematical fit of certain concepts, there is no consensus on the definitions of mass or the implications of mass increase with velocity.
The discussion reveals limitations in the definitions and measurements of mass, as well as unresolved questions regarding the implications of relativistic effects on mass. The participants acknowledge the complexity and nuances involved in these concepts.
lavalamp
I have had an interesting thought. As you may or may not know, Higgs particles are thought to be responsible for, (the "illusion" of), mass.
According to Newton, unless an external force acts on a body it will continue to travel in a straight line at a uniform velocity or stay at rest, (or words to that effect).
This leads me to the conclusion that Higgs particles resist changes to a bodies acceleration.
My theory is this:
Firstly: For each Higgs particle that acts on a particle, the mass of that particle is increased by a fixed quantized amount of mass, (ie: a very small fundamental amount, eg: 10^-100 Kg).
Secondly: When particles move faster, they pass through more space and therefore more Higgs particles act on the particles per unit time. Therefore the mass of the particles increases slightly with velocity.
Thirdly: All Higgs particles act on particles for a fixed amount of time, regardless of how fast the particle is moving. This gives the effect of accumulating mass exponentially while the velocity increases uniformly, although I admit that I haven't quite twigged where the speed of light limit comes in yet.
It does however explain why the mass stays constant with velocity, because for anyone particle traveling at a fixed velocity it will always have a fixed number of "hangers on".
Feel free to pick holes in it, add to it, make suggestions or point out things that I've over-looked etc.
All I ask is that you just don't bury me in maths.
If you have an alternative theory on why mass increases with velocity, or even why mass exists at all, I'd love to hear it.
One thing you will have to explain is why your mass does not appear to increase when it is YOU that is traveling fast.
Einstein's predictions are based on the fact that you can never determine an "absolute" velocity. IF the mass increase is caused by an accumulation of Higgies, then we would have a method of determining absolute speed, and the theory that predicted mass increase would itself be proved wrong!
Mass increases of particles traveling near light speed are well documented, but they only appear to our stationary selves to have this increase. All objects will always observe themselves to have a "rest mass."
I'm not sure if I mentioned this before but mass increase (ie. increase in resistance to change in momentum) with velocity is a direct result of time dilation and length contraction - they are one in the same phenomena.
Pmb
Methinks it's time for a new theory.
It did seem to fit with what I knew though, so it was good while it lasted. Do you know where I can read anything about Time Dilation and length contraction?
If you can get your hands on a physics textbook called "Conceptual Physics" by Paul Hewitt, you will have one of the best primers on special relativity. IT will just get you started though. before you get to the cutting edge stuff, you should also read Richard Feynman's section on Special relativity in his "Lectures on Physics" (read it in a library, or in one of those big bookstores with a cafe). He puts in more math, but it is not too difficult. You could also read Al Einstein's own book, but I find that he is not the best at explaining his own theory. After that there are HUNDREDS of books, more coming every year, explaining SR. Do a google search for "length contraction" or "time dialation" and your screen will explode.
Pmb
It seems to fit mathematically. Is this a currently accepted viewpoint?
Nobody claims that it's wrong. The only debate is what how this word ---> "mass" should be defined. And that's a hot and emotional charged debate.
Pete
Pete
In fact if you even somebody else try to measure a mass, then you even somebody else can obtain only a (rest) mass. In this sense a mass doesn't increase with velocity, nobody can to measure it because a (rest) mass is an invariant.
I disagree. One does not directly measure either mass or rest mass. One directly measures things like position and time etc.
For example: Some at sci.physics.relativity claimed that the Lorentzz force equations
F = dp/dt = q[E + vxB]
is wrong (Yeah. There are a ton of wackos there). He mumbled something about how that gives you the wrong value for the cyclotron frequency. So I derived the correct relation and made a web page on it (its a standard derivation so its no big deal).
http://www.geocities.com/physics_world/cyclotron.htm
The relation is defined as follows
r = radius of cirlce charge is moving in
B = magnitude of uniform B field
p = mv = momentum
They are related by
p = qBr = mv
or
m = qBr/v
The m defined as such is, as you know, what some call "relativistic mass" or "inertia mass" or "relativistic inertial mass" or just plain "mass." I use the last one of course.
B is a given. r is measured. velocity is measured. Therefore one gets calculates the mass m according to
m = qBr/v
The rest mass, m_o, is obtained by by solving for m in
m = m_o/sqrt[1-(v/c)^2]
Pete
  • · Replies 37 ·
  • · Replies 60 ·
