Register to reply
Slope of the perpendicular line on the other line
by Alg0r1thm
Tags: line, perpendicular, slope
Share this thread:
Alg0r1thm
#1
Apr9-14, 02:05 AM
P: 6
Why is the slope of perpendicular line on the the other defined this way:
m = slope of a particular line
m'= slope of the perpendicular line on that particular line
m*m' = -1 OR m' = -1/m
Thanks
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Simon Bridge
#2
Apr9-14, 04:25 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,961
If you have a line y=mx+c, and another line y'=m'x+c', what does m' have to be for y' to be perpendicular to y.
Draw a few lines and see.
i.e. if m=m', then the two lines are parallel.
Alg0r1thm
#3
Apr9-14, 07:59 AM
P: 6
Quote Quote by Simon Bridge View Post
You mean there is no kind of proof or something like algebraic statement which states that the perpendicular line slope would be concluded via it?
HallsofIvy
#4
Apr9-14, 08:03 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,565
One way to look at it is this: if y= mx+ b is the equation of a line, then the slope, m, is the tangent of the angle, [itex]\theta[/itex], the line makes with the x-axis. If two lines are perpendicular then they form a right triangle with the x-axis as hypotenuse. The angle one of the lines makes with the x- axis, say [itex]\theta[/itex], will be acute, the other, [itex]\phi[/itex], will be obtuse.
Looking over this I see I have used the wrong words. I meant that one will be less that or equal to 45 degrees, the other larger than or equal to 45 degrees.
The angles inside that right triangle will be [itex]\theta[/itex] and [itex]\pi- \phi[/itex] and we must have [itex]\theta+ (\pi- \phi)= \pi/2[/itex] so that [itex]\phi- \theta= \pi/2[/itex].
Now use [itex]tan(a+ b)= \frac{tan(a)+ tan(b)}{1- tan(a)tan(b)}[/itex] with [itex]a= \phi[/itex] and [itex]b= -\theta[/itex]:
[tex]tan(\phi- \theta)= \frac{tan(\phi)- tan(\theta)}{1+ tan(\phi)tan(\theta)}= tan\left(\frac{\pi}{2}\right)[/tex]
But [itex]tan(\pi/2)[/itex] is undefined! We must have the fraction on the left undefined which means the denominator must be 0: [itex]1+ tan(\theta)tan(\phi)= 0[/itex] so that [itex]tan(\theta)tan(\phi)= -1[/itex] and that last is just "[itex]mm'= -1[/itex]".
Simon Bridge
#5
Apr9-14, 08:36 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,961
Quote Quote by Alg0r1thm View Post
NO - I mean that you can start from what I wrote and work it out for yourself.
I was trying to set your feet on the right path.
HallsofIvy showed you one approach.
Register to reply
Related Discussions
Find slope of line, two points on the line are included Precalculus Mathematics Homework 2
LinAlg: Parametric Equation of a Line, given a parallel plane and perpendicular line Calculus & Beyond Homework 0
Calculate point on line, perpendicular and intersecting another line in 3d space Differential Geometry 1
Find equation of line that is perpendicular to the tangent line to the curve Calculus & Beyond Homework 6
Vector equation for a line passing through a point and perpendicular to another line Calculus & Beyond Homework 11
