Register to reply
How to Determine the Range of Strong and Weak Interaction
by Primroses
Tags: determine, interaction, range, strong, weak
Share this thread:
Primroses
#1
Apr9-14, 02:09 AM
P: 3
How can we determine the ranges of strong interactions and weak interactions?
Can calculations of relevant scattering cross sections do this?
Thanks.
Phys.Org News Partner Physics news on Phys.org
IHEP in China has ambitions for Higgs factory
The physics of lead guitar playing
The birth of topological spintronics
Simon Bridge
#2
Apr9-14, 02:50 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
Simon Bridge's Avatar
P: 12,423
The ballpark-range can be worked out by putting the rest-mass energy of the mediating boson into the HUP relations.
It can be checked impirically by working out the crossection as a function of range.
Meir Achuz
#3
Apr9-14, 02:37 PM
Sci Advisor
HW Helper
PF Gold
P: 1,992
The range of weak interactions is of the order of 1/M_W~.02 fm.
The range of strong interactions between baryons is of the order of 1/m_pi~1 fm.
The range of strong interactions between quarks is due to gluon-gluon interactions,
leading to a confining potential with a range of about 1 fm.
bcrowell
#4
Apr9-14, 07:57 PM
Emeritus
Sci Advisor
PF Gold
bcrowell's Avatar
P: 5,581
I think the OP was asking how to determine these things experimentally, not how to predict them theoretically.
The answers to these questions are completely different depending on whether you're talking about the strong interaction between two nucleons and the strong interaction between two quarks. The latter interaction is usually modeled with an interaction that is of infinite range, and that gets *stronger* with distance.
A very simple way to put an upper limit on the range of the strong force between nucleons is from the liquid drop model. The liquid drop model contains a surface tension term, and the fact that the liquid drop model does a good job of fitting nuclear binding energies tells us that this surface tension term is physically accurate. This implies that the range of the strong force is small compared to the diameter of nuclei.
Re the question of how to put a lower limit on the range of the strong force, I'm not sure what it would even mean to hypothesize that the range of the strong force between two nucleons was less than about 1 fm, since nucleons themselves are fuzzy and about 1 fm in size.
Simon Bridge
#5
Apr9-14, 09:36 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 12,423
Someone interested in the experimental foundation of the strong force should probably start with Hideki Yukawa (Nobel Prize 1935).
http://www.nobelprize.org/nobel_priz...awa-facts.html
Somewhat accessible discussion:
http://www.applet-magic.com/yukawa.htm
Weak interaction is eluding me - it looks like it was more the accumulated general success of the model rather than any direct measurement.
I think the key here would be to define what one would mean by the "range" of an interaction - i.e. what are you actually going to measure?
Register to reply
Related Discussions
Finding Range of Weak Interaction from Mass of Z Boson Advanced Physics Homework 5
Why strong interaction is short-range force? High Energy, Nuclear, Particle Physics 8
Weak and strong interaction are attactive or repulsive force? Quantum Physics 1
Weak and strong interaction General Physics 0
Strong interaction range High Energy, Nuclear, Particle Physics 6
