Efficiently Power Your AC with Direct Solar Integration | Arizona Homeowners
In summary: Solar panels - about $5/watt -> 10,000 watts about $20,000Inverter to convert to AC - I found one on sale 10,000 watts -> $ 2,000Batteries - Let's say only 4 quality boat or golf cart batteired -> $ 800Tracking frame, hardware,misc wiring-> ...
James Brady
105
Hello,
I'm in Arizona and was looking to hook up some PV panels directly to the air conditioning unit pump. Is this a reasonable goal?
I figured that I could disconnect the AC unit from grid power and then hook up the solar panels/inverter to the AC unit, but is it possible to have the grid power work hand in hand with the solar cells?
You don't need the aircon except while the sun is high in the sky?
So I was going to put on a solar/grid switch
James Brady said:
Hello,
Check with your local power utility company. They have rules and standard circuits for hooking up your local power generation to the grid. They are very important rules regarding everybody's safety, and it's illegal to connect your power generation to the grid without having your installation inspected and approved by the local power utility company.
This is very commonly done, so they will have useful resources to help you figure out how to connect up to the grid.
How big do solar panels have to be to deliver at least 5 KVA of power? How much would they cost?
Costs? That is the question with solar! The technology exists, but right now, unless have no access to the grid it is not cost effective to use solar. By the way, even a direct tie would need batteries to cover for the clouds that might pass overhead. And tracking frame and hardware / wiring I'm probably way off on costs on the low end.
Quick search yields:
Solar panels - about $2/watt -> 5000 watts about $10,000
Inverter to convert to AC - I found one on sale 7000 watts -> $ 1,500
Batteries - Let's say only 2 quality boat or golf cart batteired -> $ 200
Tracking frame, hardware,misc wiring-> $ 800
total------------------------------------------------------- $12,500
Here is the rub, electricity on the grid in my area is around $0.09 per kilowatt hour
so $12,500 = 138,889 kilowatt hours; divide that by 5 (for the 5000 watts of power of the solar sys)
and we get 27,778 hours before we break even. That assumes one time costs covers everything no maintenance or repairs etc.
I love solar and have several panels (10W - 100W) for remote use where grid is not available to run radio, charge lights, etc. And I would love to spend the money to install a system to take me completely off the grid.
However, being realistic the costs is just too expensive at the moment.
In my humble opinion.
Likes 1 person
Ok...about what I thought. Not worth the money in this case.
One thing is for sure, when someone does invent a way to "harness" the suns energy efficiently enough make steam electric power plants obsolete, they will be a multi-billionare.
There may be worthwhile savings to be made were you to use your solar power to directly drive some roof-space exhaust fans. Getting rid of the hot air trapped there will give you cooler ceilings, easing the demands on your aircon unit. ... assuming you don't already have these, of course.
A Peltier-based aircon unit would be the shot! But I think they are not very efficient. Yet.
Likes 1 person
I see, I was looking at the wikipedia article relating to cost/watt and it looks like most the cost for solar is auxiliary stuff like good inverters, installation, tracking, etc.
That is a good idea! I could easily put up a DC fan. The attic does get extremely hot during the summers here.
i'm a believer in solar water heating.
It can replace a lot of KWH.
Copper flat plate collectors are very long lived, low maintenance, and simple enough for a handyman to build.
I'm not aware of a practical solar refrigeration system . That'd be a moneymaker in the Sun Belt.
Could the refrigeration cycle that uses propane/electric heat found in most campers not use the heat from the sun in the same way? Like electricity generation, one would need a way to store the heat when the sun is not shining for total solar. But I think it would be easy to to supplement solar with electric heat/gas backup using a microcontroller to monitor the conditions and switch appropriately.
I guess you're speaking of absorption cycle?
That can be done.
I believe you need around 400 degF which is about the limit of solar collectors due to re-radiation, unless you can get selective surface such as black nickel which absorbs visible like a black body but is opaque for infrared.
The chemicals in such systems aren't conducive to home-fabrication. Ammonia precludes copper, and the bromide doesn't look simple either.
http://www.achrnews.com/articles/chemistry-101-for-absorption-chillers
When absorption chillers were first introduced, steam from an external source was used to concentrate the lithium bromide. Over the years, direct boiling of the diluted bromide has become the method of choice, and this is what is used in today’s absorption chillers.
The entire absorption chiller seems very simple, mechanically. Pumps are needed to circulate the bromide and water. A heat source is required. Heat exchangers, spray trees, tubing bundles, electrical controls, etc., complete the system. The entire operation depends upon circulating the right mix of water and lithium bromide through unobstructed piping. But there is another aspect of the absorption chiller that literally fouls up the workings of the chiller — corrosion. Lithium bromide, a highly corrosive brine, readily attacks ferrous metals such as steel.
The corrosion process generates hydrogen gas that reduces the internal vacuum inside the chiller. With the reduction in vacuum, the unit operates poorly. In addition, the debris resulting from the corrosion fouls narrow openings in spray headers, heat exchangers, etc.
Proper operation of absorption chillers, therefore, does not merely depend upon servicing the mechanical aspects of the unit. An understanding of lithium bromide chemistry is also required...
...This is, then, the chemical mechanism whereby lithium bromide attacks the internal metal components of absorption chillers. It cannot be ignored because the action creates havoc on the workings of the unit. Owners and operators of absorption chillers must deal with its chemistry as well as its mechanical systems.
so what's a home handyman to do?I thought about this a lot when i lived in S Florida.
If one could use solar generated steam to pull high vacuum on a reservoir of water,
and circulate that water through a heat exchanger placed right behind your central A/C filter,
one would have "booster" for his central A/C which would reduce the amount of time his compressor has to run.
Back of the envelope calcs said if you can evaporate 55 gallons of water over course of a day you'll provide a ton of cooling all day long. Typical central unit where i lived was two or three tons but didn't run continuously, so a ton of boost would make a sizable dent in the electric bill.
Water as the working fluid avoids a lot of problems. Google "refrigerant R718"
And it could be a batch process instead of continuous . If you could arrange it so gravity does your pumping - aficionados of low-tech like myself would crave it.
Somebody will come up with a practical rooftop system surely.
Here's some more ideas.
http://users.ntua.gr/rogdemma/A Review for Absorption Refrigeration Technologies.pdf
What is the "Direct Solar to AC" idea?
The "Direct Solar to AC" idea refers to the concept of using solar energy directly to power AC (alternating current) devices, without the need for an inverter or battery storage system.
How does the "Direct Solar to AC" idea work?
The idea works by using specialized solar panels that are able to convert DC (direct current) electricity from the sun directly into AC electricity that can be used to power household appliances and electronics.
What are the advantages of the "Direct Solar to AC" idea?
One major advantage is that it eliminates the need for an inverter, which can be costly and inefficient. It also allows for more efficient use of solar energy, as the electricity is not being converted and stored before being used.
Are there any disadvantages to the "Direct Solar to AC" idea?
One potential disadvantage is that the specialized solar panels needed for this system may be more expensive than traditional solar panels. Additionally, this system may not be suitable for all types of AC devices and may require additional equipment for compatibility.
Is the "Direct Solar to AC" idea currently being used?
Yes, there are companies and individuals currently using this idea and implementing it in their homes and businesses. However, it is not yet widely adopted and may still be considered a newer technology in the renewable energy industry.
  • Electrical Engineering
  • Mechanical Engineering
