Register to reply
1000 kilo newton meter (K/Nm) torque
by parsci
Tags: 1000, k or nm, kilo, meter, newton
Share this thread:
parsci
#1
Apr16-14, 07:14 AM
P: 2
i want to produce 1000 K/nm of torque using motors and gear , output rpm needed is 30 and 1000 k/ nm of torque
1) motor kva? and rpm ?
2) gear ratio and size ?
3) does it also require flywheel ?
Phys.Org News Partner Engineering news on Phys.org
Philips introduces BlueTouch, PulseRelief control for pain relief
3-D printing leads to another advance in make-it-yourself lab equipment
Nanoscience makes your wine better
dauto
#2
Apr16-14, 10:47 AM
Thanks
P: 1,948
You mean you want to produce 1000 kNm and a frequency of 30 RPM. The way you wrote it makes no sense.
dauto
#3
Apr16-14, 10:48 AM
Thanks
P: 1,948
I also have no idea what a motor's kva is. No doubt another botched unit usage?
f95toli
#4
Apr16-14, 11:01 AM
Sci Advisor
PF Gold
f95toli's Avatar
P: 2,262
Quote Quote by dauto View Post
No, the units are correct (although they should be written kVA). Motors (and e.g. transformers) are always rated in VA, not W. The former is the unit for apparent power whereas the latter is the unit for real power. They are related via the power factor of the load.
Nugatory
#5
Apr16-14, 12:40 PM
Mentor
P: 3,960
Quote Quote by parsci View Post
You will get better answers if you solve the problem yourself. Here's a hint to get you started: You already have enough information to calculate the power output, so you know how much power you need the motor to deliver. That will tell you what the motor kva must be; and when you're considering a motor it will be specced to deliver that power at a particular RPM. If that RPM is not 30, then you will need gears in whatever ratio will get you from the motor RPM to your desired 30RPM output.
Whether you need a flywheel or not will depend on how variable the load is.
parsci
#6
Apr16-14, 01:18 PM
P: 2
Quote Quote by Nugatory View Post
Thnks for reply , help me in getting output torque
150 kva motor 3 phase 960 rpm using double stage gear 1st stage 78 inch dia Reducing rpm 10:1 2nd stage gear 36 inch dia reducing 3:1 ,how much the output torque
Nugatory
#7
Apr16-14, 01:26 PM
Mentor
P: 3,960
You want 1000 kNm of torque at 30 RPM. What power (in watts) does that represent?
If your motor delivers that power while turning whatever revs are needed to get 30 RPM after going through the gearing, it's generating the necessary torque.
(Although wise engineers will choose a motor that provides some excess capacity).
Baluncore
#8
Apr17-14, 01:53 AM
Sci Advisor
Thanks
P: 1,957
The practical implementation of such a system will be limited by the mass of the gear wheels and the box that holds them together. The gear box will weigh less if you use an extra stage with a final bull gear ratio closer to 3:1 than 10:1.
You might consider using an internal gear which has more tooth contact. An epicyclic with multiple planets could also help reduce total weight.
An obvious alternative to such a heavy gearbox would be to use a hydraulic motor. A hydraulic “gear motor” for example exerts the hydraulic force on many teeth. The gear ratio is determined by the relative fluid volume per revolution of the motor and the pump. It is self lubricating and the hydraulic fluid can be cooled if necessary.
Baluncore
#9
Apr17-14, 07:26 PM
Sci Advisor
Thanks
P: 1,957
Here is some data on big planetary gearboxes.
http://www.boschrexroth.com/mobile-h...73&Language=EN
Register to reply
Related Discussions
Using torque to find mass of meter stick Introductory Physics Homework 11
Intuitive meaning for Newton-meter Classical Physics 1
Principle of Torque Meter Mechanical Engineering 1
How To Determine Newton Meter Force Introductory Physics Homework 1
Kilo gram to a centi meter Introductory Physics Homework 2
