Could the Green Goblin's Grip Overcome Static Friction on the Bridge?
The discussion centers on the physics of the Green Goblin's ability to hold onto a bridge while pulling a cable car weighing approximately 23,000 lbs. The calculated maximum static friction (FsMAX) between the Goblin and the bridge is 128 lbs, based on a coefficient of static friction of 0.61, Goblin's weight of 95 kg, and gravity. Factors such as the angle of the cable pull, surface conditions of the bridge, and the Goblin's grip strength significantly influence the actual force required to maintain his position. The calculations provided are accurate under the assumption of horizontal pull, but additional variables must be considered for a comprehensive analysis.
  • Understanding of static friction and its calculations
  • Knowledge of forces and weight in physics
  • Familiarity with coefficients of friction
  • Basic grasp of vector forces and angles
  • Research the effects of surface conditions on the coefficient of static friction
  • Learn about vector decomposition of forces in physics
  • Explore advanced friction models beyond basic coefficients
  • Investigate the biomechanics of grip strength in fictional characters
Physics enthusiasts, comic book fans analyzing character abilities, and anyone interested in the application of physics in fictional scenarios.
DKirby
I'm working on the physics behind a Scene in Spiderman, where the Green Goblin is standing on top of a bridge, holding a cable. along that cable is a cable car full of screaming little kids. I calculated the force pulling on the Goblin to be about 23,000lbs...and I'm sure even with his 800% strength increase he couldn't hold on to that.
So now I'm working on calculating the static friction between the Goblin and the bridge, to see if even if he was strong enough, if he would have enough friction to even stay put. What I have is
FsMAX (Max force that can be applied before object starts to move) = (Coefficient of static friction) * mass * gravity.
This comes out to be
FsMAX = (0.61)(95)(9.8) = 128 lbs
Where I'm guessing the Goblin's suit's material is aluminum, and the beam he's standing on his metal, and the Goblins weight + suit is 95kg.
My question is, is this calculation right? Or, would it take more than the 128lb force to start his feet moving because he's actually pulling back using force on the rope? And if that is the case, how would I go about finding the actual FsMAX?
Yep, good job Kirby. The force you calculated assumes a 0.61 coefficient of static friction, and that force is able to resist the cable pulling on the Green dude assuming the cable is pulling horizontally. Of course, if the cable is pulling at some downward angle, there is some increase in static friction because the downward angle gives the Goblin some additional downward force to augment his weight. But assuming a horizontal pull, you've got it figured out. Of course, cartoon characters can even resist gravity if the ground drops out from underneath them... so long as they don't realize it. Maybe some related phenomenon occurred to GG...
Your calculation for the maximum static frictional force is correct. However, there are a few other factors that could affect the actual force required for the Goblin to hold on to the bridge and the cable car.
Firstly, the coefficient of static friction may vary depending on the surface conditions of the bridge and the Goblin's suit. For example, if the bridge is wet or covered in debris, the coefficient of friction may decrease, making it harder for the Goblin to hold on.
Secondly, the force of the Goblin pulling on the cable may also affect the required static frictional force. If the Goblin is pulling with a significant force, it could increase the required frictional force to keep him in place.
Lastly, the Goblin's strength and grip also play a role. If his grip is not strong enough, he may not be able to hold on even if the maximum static frictional force is enough.
To get a more accurate calculation, you could consider these factors and also try to estimate the force the Goblin is pulling on the cable with. This would give you a better understanding of whether or not he would be able to hold on in this scenario.
17K
19K
28K
