About arguments of functions
  • Thread starter Jhenrique
  • Tags
    Functions
It is not the same as ##\omega t##.2) I was thought about what is ##\sigma##, so, I realized that exist a similarity between ##\exp(-st)## and ##\exp(-\frac{d\log(z)}{dt}t)##. If ##\frac{d \log(z)}{dt}## is constant, thus ##\frac{d \log(z)}{dt} \times t## is the antiderivative of ##\frac{d \log(z)}{dt}##, ie, ##\log(z)##. ##z = \exp(\log(z)) = \exp( \log(r) + i \theta)
Jhenrique
685
Commonly I see ##\sin(\omega t + k x)## I ask myself, if ωt is equal to θ thus kx is equal to what??
Also, the kernel of the laplace transform is ##\exp(-st)##, very similar to kernel of the fourier, that is ##\exp(-i \omega t)##, and and same question again, if ωt is equal to θ thus st is equal to what??
Finally, I see sometimes a connection between s and ω, that is ##s = \sigma + i \omega##, but, again, what this equation means and what is σ?
Mathematics news on Phys.org
What do you mean?? I'm sorry, but this question makes no sense at all.
https://en.wikipedia.org/wiki/Sinusoidal#General_form
What exactly you don't understand? k is the wave number, x is the coordinate spatial, ω is the angular velocity and t is the time. If the product ωt results the angle θ so the product kx results which physical/mathematical quantity?
I'm not sure whether ##\sigma## has a physical meaning or not, but mathematically it is a "decay" factor which can allow the Laplace transform to converge even if the Fourier transform (which is the special case with ##\sigma = 0##) does not. Since ##e^{-st} = e^{-(\sigma + i \omega)t} = e^{-\sigma t}e^{-i \omega t}##, the absolute value ##|e^{-st}|## is ##e^{-\sigma t}##. Thus if we compute the Laplace transform of some function ##f##, then
$$\left|\int_{-\infty}^{\infty} f(t) e^{-st} dt\right| \leq \int_{-\infty}^{\infty} |f(t)| e^{-\sigma t} dt$$
So if ##f## decays fast enough on one of the intervals ##(0,\infty)## or ##(-\infty, 0)## (for example, if its support on one of the intervals is compact) and grows no faster than exponentially on the other interval, the Laplace integral can converge for some values of ##\sigma##.
Putting it another way, the Laplace transform of ##f(t)## is the same as the Fourier transform of ##f(t)e^{-\sigma t}##.
If ##\sin(\omega t+kx)=\sin\theta##, then ##\theta=\omega t+kx## not ##\omega t##. I am guessing this is what you mean, but I may be misinterpreting. If ##x## is constant, then ##\theta## changes as ##\omega t## or if ##t## is held constant ##\theta=kx##.
Reading the wiki article, I don't see where your confusion is coming from. I do not see ##\theta=\omega t## in that article.
[itex]\sigma [/itex]is in there to study exponential responses. Not everything is sinusoidal. An interesting youtube series that covers both Laplace and Fourier transforms is at https://www.youtube.com/watch?v=ZGPtPkTft8g&list=PLUMWjy5jgHK3j74Z5Tq6Tso1fSfVWZC8L
1) Are you sure? IMO, ##\sin(\theta) = \sin(\omega t) \neq \sin(kx)##. Is sure that exist a relationship between ##\theta##, ##t## and ##\omega##, that is ##\frac{d\theta}{dt}=\omega##, if ##\omega## is constant, so ##\theta = \omega t##. The only way of connect ##\theta## and ##x## is saying that the wave number ##k## is the derivative of ##\theta## wrt ## x ##. Is this true?
2) I was thought about what is ##\sigma##, so, I realized that exist a similarity between ##\exp(-st)## and ##\exp(-\frac{d\log(z)}{dt}t)##. If ##\frac{d \log(z)}{dt}## is constant, thus ##\frac{d \log(z)}{dt} \times t## is the antiderivative of ##\frac{d \log(z)}{dt}##, ie, ##\log(z)##. ##z = \exp(\log(z)) = \exp( \log(r) + i \theta) = \exp(\int \frac{d}{dt}(\log(r) + i \theta) dt )##
## = \exp(\int \frac{v_r}{r} + i \omega\;dt) = \exp((\frac{v_r}{r} + i \omega) t) = \exp((\sigma + i \omega)t) = \exp(st)##. All this means that the kernel of the laplace transform is the variable complex ##z## and that the laplace transform leads from time t to complex plan ##\frac{d \log(z)}{dt}##.
3) If the laplace transform has ##\sigma \neq 0## and ##\omega \neq 0## and the Fourier transform has ##\sigma = 0## and ##\omega \neq 0##, for the party be complete, shouldn't there is a transform* that has ##\sigma \neq 0## and ##\omega = 0##?
* ##\int f(t) \exp(-\sigma t) dt##
If you want to define ##\theta=\omega t##, then sure. But why would you do that if there is also a dependence on position.
Sure, if ##\theta=\omega t+kx## then ##\frac{\partial\theta}{\partial t}=\omega## and ##\frac{\partial\theta}{\partial x}=k##. The first implies ##\theta=\omega t+f(x)## and the second implies ##\theta=kx+g(t)##.
I have never seen ##\theta=\omega t## in a situation where ##\sin\theta## was a function of both time and position. Usually ##\theta## (except in geometry) is just an imaginary angle (not as in ##i##) that stands in for whatever argument is being used. If you write ##\sin(\omega t+k x)## then the argument is ##\omega t+kx##. If you want to, you could define ##\phi=kx##, but I have not ever seen this done unless ##x## is constant and then ##\phi## is just a phase shift. This isn't really a matter of right and wrong. I just don't think it is normally done the way you show it and I can't think of a reason to do it that way.
You could define such a transform, say
$$\tilde{f}(\sigma) = \int f(t) \exp(-\sigma t) dt$$
but would you be able to recover ##f(t)## given ##\tilde{f}(\sigma)##? If not, then it would not be a very useful transform.
Yeah, I'm assuming that exist the inverse. I didn't think in the superior and inferior limits nor in the inverse, I just did think in the ideia of transform a function from time to sigma.
Actually, this transform $$\tilde{f}(\sigma) = \int_{-\infty}^{+\infty} f(t) \exp(-\sigma t) dt$$ or $$\tilde{f}(\sigma) = \int_{0}^{\infty} f(t) \exp(-\sigma t) dt$$ has the face of the laplace transform. So this transform isn't a repeated ideia?
Of course wouldn't be a repeated ideia if this new transform leads from time ##t## to radial velocity ##v_r## (like Fourier that leads from time ##t## to angular velocity ##\omega##). So the transform would have a new face: $$\tilde{f}(v_r) = \int_{-\infty}^{+\infty} f(t) \exp\left(-\frac{v_r}{r}t\right) dt$$
But of course this analogy didn't go unnoticed for none good mathematical, however, I never see nobody mention this analogy. So, this make sense?
For my surprise, I discovered that ##\theta = \theta (x, t)##! This because ##\theta## is only an argument of a function and not a spatial coordinate, as I thought that was, (after all, how could a independent spatial coordinate be function of another spatial coordinate and of the time too, this no make sense). So, ##\frac{\partial \theta}{\partial t}=\omega## and ##\frac{\partial \theta}{\partial x} = k##, according with (https://en.wikipedia.org/wiki/Frequency#Other_types_of_frequency), from this follows 2 line of development:
$$f(\theta) = f(\omega t) = f(2\pi \nu t) = f\left(\frac{2\pi t}{T} \right)$$ $$f(\theta) = f(k x) = f(2\pi \xi x) = f\left(\frac{2\pi x}{\lambda} \right)$$
Being:
##\omega## = angular temporal frequency
##\nu## = temporal frequency
##k## = angular spatial frequency
##\xi## = spatial frequency
If the laplace transform is for problems with temporal dependence and the Fourier transform is for problems with spatial dependence, so is correct say that the laplace transform maps between the time ##t## and the angular temporal frequency ##\omega##, while that the Fourier transform maps between the time ##t## and the angular spatial frequency ##k## (or spatial frequency ##\xi##)? If yes, thus no exist a connection between laplace and fourier, same with ##\sigma = 0##, because the kernel of the laplace would be ##\exp(- i \omega t)## while that the kernel of Fourier would be ##\exp(-i k t)##, right?
1. What are arguments of functions?
Arguments of functions are the values or variables that are passed into a function when it is called. They are used to provide the function with necessary data or inputs to perform a specific task. Arguments are enclosed within parentheses and separated by commas.
2. How many arguments can a function have?
A function can have any number of arguments, including zero. This is determined by the programmer when the function is defined. Some functions may require several arguments to perform a complex task, while others may not require any arguments at all.
3. Can arguments have default values?
Yes, arguments can have default values. This means that if no argument is passed into the function, it will use the default value instead. Default values are set by the programmer when the function is defined and are specified within the parentheses after the argument name.
4. How are arguments passed into a function?
Arguments can be passed into a function in two ways: by value or by reference. When passed by value, a copy of the argument's value is created and used within the function. When passed by reference, the function has access to the original argument and any changes made to it within the function will also affect the original argument.
5. Can arguments be of different data types?
Yes, arguments can be of different data types. This allows for flexibility in the types of inputs that can be passed into a function. The programmer must specify the data type of each argument when defining the function, and the arguments passed in must match the defined data types.
  • General Math
  • Topology and Analysis
  • General Math
  • Electrical Engineering
  • Differential Equations
