Calculating Pressure and Mass of Ethane Gas in a Flask
  • Thread starter Thread starter janiexo
    Gas Ideal gas
The discussion revolves around calculating the pressure and mass of ethane gas in a flask under varying temperature conditions. The problem involves the ideal gas law and concepts related to gas behavior when subjected to temperature changes.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the ideal gas equation and the conditions of pressure and temperature at different stages of the process. Questions arise regarding the constancy of pressure and temperature before and after the stopcock is closed, as well as the implications of Boyle's and Charles's laws.
Some participants have offered guidance on the relationships between pressure, volume, and temperature, suggesting the use of the ideal gas law. There is a recognition of the need to understand how certain properties remain constant during the process, though no explicit consensus has been reached on the final values.
Participants are working under the constraints of the ideal gas law and the specific conditions of the problem, including the initial and final temperatures and pressures. The discussion reflects uncertainty about the behavior of the gas when the stopcock is closed and the flask is cooled.
janiexo
I'm really struggling with this concept and can't seem to get my head around it. I don't know why because it seems simple enough but I can't seem to get the answer :mad::
Question:
A flask with a volume 'V', provided with a stopcock, contains ethane gas (C2H6) at a temperature of T_0 and atmospheric pressure p_0. The molar mass of ethane is M. The system is warmed to a temperature of T, with the stopcock open to the atmosphere. The stopcock is then closed and the flask cooled to its original temperature.
a) What is the final pressure of ethane in the flask?
b) How many grams of ethane remain in the flask (use 'R' for ideal gas constant)?
Okay, first what is the "ideal gas equation"? What are the starting pressure, temperature and what are the pressure and temperature just before the stopcock is closed? What must stay constant once the stopcock is closed? So what must change? What are the temperature and pressure at the end?
Ok, well the equation is pV = nRT
So at the start it's pressure is p_0 and temperature T_0
Before it's closed the temperature is T and the pressure is ... I don't know what the pressure is, would it stay at p_0?
So once it's closed the volume stays constant so the pressure must change. The temperature at the end is T_0 once again but i have no idea about the pressure.
HallsofIvy gave you good pointers. During each process step, there is one property that remains constant. Try to understand what Charles and Boyle's laws say(in the same order).
Use (p_1*V_1)/T_1 = (p_2*V_2)/T_2
You know volume remains constant, you know the temperature, then you can work out the final pressure.
Then to find the mass, just use pV = nRT.
Thanks for your help everyone, I understand it now. Things seem a lot clearer in the light of day I guess :)
