With sending one pulse into a motor, does that make it move a step?
  • Thread starter Aerozeppelin
  • Tags
    Motor Pulse
In summary, changing the amplitude or width of these pulses does not always result in an increase in motor speed.
Aerozeppelin
Does changing the amplitude or width of these pulses do anything?
I'm trying to figure out how to increase a motors speed!
Thanks in advance!
A single short voltage pulse, applied to a DC motor, will cause it to advance slightly.
The area of the pulse is voltage * time which does not represent power, except in a resistor.
A motor is partly inductive so the current pulse will lag the voltage pulse. The power applied to the motor is the integral of (the instantaneous voltage multiplied by the instantaneous current).
Changing pulse amplitude or width will change the power delivered. But because of the inductive lag there will not be a simple relationship between amplitude, width and motor advance.
Likes 1 person
Thanks in advance!
If you mean a stepper motor and controller it's based on pulse speed and the number of pulses.
http://orientalmotor.com/products/stepper-motors/index.html
Likes 1 person
Thanks in advance!
you didn't specify what type of motor, stepper, DC or AC. Stepper is a set of pulses with pulse patterns for the next step. DC is a similar process. AC motors speed can be increased with the use of a Variable speed drive. VFD, this type utilizes pulse width modulation which is a simulated AC current via digital pulses. Then amplitude and timing of the PWM signals can then be used to control the rotations of the AC motor.
edit: just noticed the title specifying step
check the specifications on your particular motor, however it will have similar patterns as per this article
http://hibp.ecse.rpi.edu/~connor/education/IEE/lectures/Lecture_8_Stepper_motors.pdf
Likes 1 person
I can provide some insight into the concept of pulse control in motors. Sending one pulse into a motor will not necessarily make it move a step. The motor's movement is dependent on various factors such as the type of motor, its design, and the amount of force required to move the load attached to it. One pulse may not provide enough force to overcome the load and initiate movement.
However, changing the amplitude or width of the pulses can have an impact on the motor's speed. The amplitude of the pulse refers to the strength or intensity of the signal, while the width refers to the duration of the pulse. By adjusting these parameters, you can control the amount of force and the duration of the force being applied to the motor, which can affect its speed.
To increase a motor's speed, you may need to adjust the pulse parameters to provide enough force to overcome the load. It is also important to consider other factors such as the motor's voltage, current, and torque capabilities.
I would recommend conducting further research and experimentation to determine the most effective pulse control for your specific motor and desired speed. There may also be other methods, such as using a motor controller or changing the gear ratio, that can help increase the motor's speed. I hope this information helps in your quest to increase the motor's speed.
1. How does sending one pulse into a motor make it move a step?
When a pulse is sent into a motor, it triggers an electromagnetic field that interacts with the permanent magnets inside the motor. This interaction causes the motor's rotor to rotate, resulting in a step or movement.
2. What is the purpose of sending only one pulse into a motor?
Sending only one pulse into a motor is a common method used in stepper motors to control its movement. By sending a series of pulses at specific intervals, the motor can be precisely controlled to move in small, incremental steps.
3. Does the speed of the pulse affect the motor's movement?
Yes, the speed of the pulse can affect the motor's movement. The faster the pulses are sent, the faster the motor will rotate. However, there is a limit to how fast the pulses can be sent before the motor's movement becomes unstable.
4. Can a motor move multiple steps with just one pulse?
No, a motor typically requires multiple pulses to move multiple steps. However, some advanced stepper motors have features that allow them to move multiple steps with just one pulse, but this is not the standard operation for most motors.
5. What factors can affect the accuracy of a motor's movement with one pulse?
The accuracy of a motor's movement with one pulse can be affected by various factors, such as the motor's design, the quality of the pulse signal, and external factors like temperature and vibration. It is essential to consider these factors when designing a system that requires precise motor movement.
  • Electrical Engineering
