Register to reply
Waterproofing lectures
by theyusufmasood
Tags: electronics, notes or resources, waterproofing
Share this thread:
theyusufmasood
#1
Apr21-14, 02:54 PM
P: 13
Hi!
Does anyone know where I'd be able to find good notes/ lectures on waterproofing? Specifically for electronic products, if possible? Please provide me with some links if so.
Many thanks
Phys.Org News Partner Engineering news on Phys.org
ESA investigates an alternative, environmental-friendly method of corrosion resistance
The oscillator that could makeover the mechanical watch
Engineers study bats to improve aviation travel
Simon Bridge
#2
Apr21-14, 10:15 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,135
Your request is too general for the answers to be much use.
Answers go from "use an umbrella" to "put it in a plastic bag", or "set it in wax", to "coat it with a hi-tech nanostructure". But waterproofing is not, on the whole, much of a big deal subject scientifically.
You will not find lectures specific to "waterproofing electronic components" - not in general.
i.e. you won't find lectures on the best plastic bags to put your electronics in. But you will find lectures on specific methods in terms of breakthrough technologies, or as part of a broader subject such as water-repellant films.
So what do you need the information for?
theyusufmasood
#3
Apr22-14, 01:12 PM
P: 13
Quote Quote by Simon Bridge View Post
Hi, thanks for your reply. I need the information for the best way to waterproof an interface housing a micro controller, Li-ion battery, and a few buttons. The product would be used in a bath tub.
AlephZero
#4
Apr22-14, 01:55 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,293
A practical answer is find out about the international standard IP ratings, and then buy an enclosure and switches that have been tested to meet your requirements.
http://en.wikipedia.org/wiki/IP_Code
Simon Bridge
#5
Apr22-14, 09:45 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,135
Is this something you have already built yourself or is it in the design stage?
What, specifically, needs to be waterproofed (a box, a set of plugs, keyboard, touch-screen... )?
The short answer is: put it in a waterproof container.
If it is yet to be build, then AlephZero is correct - use components that are rated to the required standard.
Something like, say, an Arduino motherboard will need an appropriately rated container for instance.
If it is just for you then you can probably get away with improvising something - but reviewing what manufacturers do to meet a particular rating will tell you what standard you have to meet.
theyusufmasood
#6
Apr23-14, 11:17 AM
P: 13
Thank you for your response. My product is in the final design phase. The part I need to waterproof is the remote control for a bath lift which will house an arduino micro controller, a battery, and a couple of buttons.
I will need to specify the waterproofing methods I have implemented as well as specifying the details for manufacture. I can't seem to find any resources on industry standard waterproofing techniques, though. Do you have any suggestions? Thanks
Mordred
#7
Apr23-14, 05:41 PM
Mordred's Avatar
P: 1,857
National electrical code, Intrinsic protection ratings.. You will probably want IP67 electrical box.
key note "Do not overtorque the box lid bolts" you will over compress the gasket which reduces the rating.
http://www.anaheimautomation.com/man...ng%20Codes.pdf
Mordred
#8
Apr23-14, 05:50 PM
Mordred's Avatar
P: 1,857
Quote Quote by AlephZero View Post
didn't notice this reply earlier in the thread,
Simon Bridge
#9
Apr23-14, 09:33 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,135
Use an industry standard waterproof RC box.
You should consult your supplier - tell them your needs and they will be able to supply an appropriate box.
See post #7.
OTOH: if you want to make your own to-standard box, then the standard waterproofing would involve rubber gaskets around the box seams and the keyboard would have a solid rubber or flexible plastic cover fixed watertight. This is not rocket science. You've seen devices like this.
If you have to meet a standard quickly - over-engineer the prototype.
Register to reply
Related Discussions
The need for waterproofing... Electrical Engineering 1
MIT lectures Academic Guidance 6
Waterproofing question General Discussion 14
MIT lectures Educators & Teaching 2
Lacquer for waterproofing low voltage circuits Electrical Engineering 3
