Register to reply
Leakage rate units
by Runei
Tags: leakage, rate, units
Share this thread:
Runei
#1
Apr22-14, 09:18 AM
P: 140
Hello,
At my work I'm working with testing the leakage rate of a gas system, and right now im trying to gain some understanding of it all. However, there are some things which are very confusing to me, in regards to these rates.
Searching the internet I find several different ways to describe the leak rate, some of mL/min and some are mbar*mL/min.
To me, the first one seems to only be usable in systems with incompressible liquids, and the second is usable in systems using gas.
My intuition so far tells me that using the ideal gas law, the change in pressure over time (due to leakage) will be equal to
[itex]\Delta p \cdot V = \Delta n RT[/itex]
The temperature can be approximated to be constant, and the volume of the system is constant (its an aluminium gas string with valves and such).
Using this, we correct leakage rate units would be
[itex]\frac{\left[p\right]\left[V\right]}{\left[t\right]}[/itex]
Is this all there is to the story, or is there something I am missing?
Thank you,
Phys.Org News Partner Engineering news on Phys.org
Eye implant could lead to better glaucoma treatment
Electricity helping the blind navigate
Lawsuits challenge US drone, model aircraft rules (Update)
Mordred
#2
Apr23-14, 07:19 PM
Mordred's Avatar
P: 1,857
All leak rate units consist of three components:
1) Pressure (mbar, atm or Pa)
2) Volume (l, cc or m)
3) Time (s or m).
from that you can see a leak rate is two possible scenarios
-a changing volume (2) in a given time (3) at a certain pressure (1)
-a changing pressure (1) in a given time (3) at a certain volume (2).
so your scenario is the second one.
The pressure drop can be converted to a leak rate by multiplying the pressure drop with the inner volume of the part and by then dividing the result by the measurement time needed for the pressure drop.
which is the same as your equation
so you got it.
just make sure you look at the pressure units, for proper conversion. for example a pascal is
newton per square meter. a bar is 100,000 Pa
Register to reply
Related Discussions
Find units of rate constants and write reactions Biology, Chemistry & Other Homework 11
Rate of leakage from box Introductory Physics Homework 1
Leakage rate between two pipes & gasses General Physics 1
Thermodynamics: PPM, Volume, and time into leakage rate. Gas Laws, Helium Classical Physics 0
Help me with the leakage rate of a crack in a pressure pipe. Mechanical Engineering 7
