Register to reply
Working out Motor power?
by PC22
Tags: motor, power, working
Share this thread:
PC22
#1
Apr22-14, 09:52 AM
P: 6
I am working on a timelaps project so I need my motor to move very slowley, the motor I am using has a max voltage of 24V and a stall current of 1 Amp
The motor I want to use is on this link:
http://www.dynamicperception.com/EZ-...r-p/dp-dcm.htm
This motor will need to lift vertically 117N (12kg) of load to a height of1.3m (1300mm) in 60 mins (3600s) at a constant speed.
I need to find out the work done by the motor and convert it in to Volts?
so far I have:
P=W/T
W=117N
T=0.36m/s
So: P=117/0.36 =325W I then times this by the time (3600s) to get the work done 1170000J
Is this correct ?
Can some out tell me how many volts this is ?
Any help would really be appreciated
Phys.Org News Partner Engineering news on Phys.org
Tiny UAVs and hummingbirds are put to test
Britain to trial driverless cars from 2015
NIST corrosion lab tests suggest need for underground gas tank retrofits
adjacent
#2
Apr22-14, 10:00 AM
PF Gold
adjacent's Avatar
P: 1,466
Quote Quote by PC22 View Post
so far I have:
P=W/T
W=117N
T=0.36m/s
Is this correct ?
That's incorrect.The work done can be found by W=F.d
Why did you write T as m/s?Isn't that the time taken(s)?or is it the constant speed given in the question?
And the W is not the force.Power =Work/time taken.
PC22
#3
Apr22-14, 12:47 PM
P: 6
Care to help me work this out, please?
Register to reply
Related Discussions
Working on a blower which is directly coupled with motor Mechanical Engineering 4
The working of an electric motor and generator Introductory Physics Homework 4
A question about DC motor (input power, output power) General Physics 3
Stepper Motor Controller only working on a particular power suppy? Electrical Engineering 24
Power in / power out for electric motor Engineering Systems & Design 7
