Massive Pulley Dilemma: How to Account for Acceleration?
  • Thread starter dkb12085
  • Tags
    Pulley
In summary, the conversation discusses the mechanics of a system involving a string wrapped around a massive pulley and a block at the end. The tension in the string is the same at both ends if the string is considered massless, but if the string has significant mass, the tension will increase as one moves up the string. The block and the pulley have the same linear acceleration, but the pulley also has a corresponding rotational inertia which is taken into account in the equation T = I \alpha.
dkb12085
Hi all:
I am studying the mechanics of a system where there is string wrapped around a massive pulley, and a block at the end of the string.
Correct me if any of this is wrong, but the system (pulley and block) must have the same linear acceleration. So, in the case that the pulley is much more massive than the block, it will require greater torque, and subsequently force to give it the same acceleration.
How is this accounted for? Does the string have different tension around the pulley than it does at the block end?
Isn't it true that Tension= mg-ma because it is exerting upward force on the block?
Thank you for your efforts in explaining this!
Thank you,
dkb12085
If you consider the string to be massless then the tension at the pulley end will be the same as at the block end.
For real strings, if short or lightweight, you can make the assumption that the string mass is negligable in comparison the the block.
If the string length is longer or more massive, then the mass of the string and the mass of the block both contribute in the acceleration of the pulley. As one moves up the string, starting from the block, the mass below a particular position increases due to the addition of the incremental mass of the string below. For that reason, the tension as one moves up the string, where the mass of the string is not negligable, also increases.
Like you said, the block, the string, and the contact of string at the pulley all have the same linear acceleration.
While the block has translational inertia, as evident by the formula F=ma ( a more massive object requires more of a force for the same acceleration as a less massive object ), the pulley has a corresponding rotational inertia designated as moment of inertia ( mass moment of inertia ) about the axis of rotation.
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
The corresponding rotational equation is T = I [itex]\alpha[/itex], ( [itex]\alpha[/itex] is Greek alpha symbol lower case )
where T = torque, I = mass moment of inertia, a = angular acceleration
http://theory.uwinnipeg.ca/physics/rot/node5.html
1. How do you determine the acceleration of a pulley system?
To determine the acceleration of a pulley system, you must first calculate the net force acting on the system. This can be done by considering the forces acting on each individual pulley and the object connected to the pulley. Once the net force is determined, you can use Newton's second law of motion (F=ma) to calculate the acceleration.
2. What is the role of friction in a pulley system?
Friction plays a crucial role in a pulley system as it can affect the motion and acceleration of the system. Friction can cause a decrease in the net force acting on the system, leading to a decrease in acceleration. It can also cause the pulleys to rotate at different rates, affecting the overall motion of the system.
3. How do you account for the mass of the pulley in the acceleration calculation?
The mass of the pulley must be included in the acceleration calculation as it is a part of the overall system. The mass of the pulley can be added to the mass of the object being lifted or lowered, and then the total mass can be used in the acceleration equation.
4. Can the angle of the pulley affect the acceleration of the system?
Yes, the angle of the pulley can have an impact on the acceleration of the system. When the angle of the pulley changes, the direction of the force acting on the object also changes, which can affect the net force and ultimately the acceleration of the system.
5. How can you account for the tension in the rope when calculating the acceleration?
The tension in the rope must be taken into consideration when calculating the acceleration of a pulley system. This tension can be calculated by considering the forces acting on the rope and the angle of the rope. The tension can then be included in the net force calculation to determine the acceleration of the system.
  • Mechanics
