Register to reply
Higgs boson quantum numbers
by Jochent
Tags: boson, higgs, numbers, quantum
Share this thread:
Jochent
#1
Apr24-14, 12:28 PM
P: 2
Hi everyone,
I have studied QFT, the SM and the Higgs mechanism when I was in university and after reading an article from CMS (CERN) about the spin-parity measurement of the HZZ channel, which shows that [itex]J^{P}=0^+[/itex] is favoured versus [itex]J^{P}=0^-[/itex], I went back to the theory of the Higgs boson.
I am struck by the fact that the theory books do not explain how the quantum numbers of the Higgs boson are deduced. (in particular parity P, charge conjugation C and time reversal T) The books that I have just cover that the SM Higgs boson has [itex]J^{PC}=0^{++}[/itex].
I would like to understand how one deduces this. Is this extracted from the Higgs Lagrangian and if so, how does one do it?
Thanks a lot !
Phys.Org News Partner Physics news on Phys.org
Optimum inertial self-propulsion design for snowman-like nanorobot
The Quantum Cheshire Cat: Can neutrons be located at a different place than their own spin?
A transistor-like amplifier for single photons
Bill_K
#2
Apr24-14, 12:59 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
Since the vacuum state contains a Higgs condensate, the Higgs boson must also have the quantum numbers of the vacuum, namely 0++.
Vanadium 50
#3
Apr24-14, 01:57 PM
Mentor
Vanadium 50's Avatar
P: 16,177
Bill is correct, provided that you consider only the simplest Higgs models. If you put in a second Higgs doublet, you get two charged Higgses, and three neutrals. Two of the three neutrals are 0+ and the third is 0-.
In the simplest model, you need hhh and hhhh couplings. If the Higgs held any conserved parity quantum number that was odd, you could not have hhh couplings. So they are all even.
Jochent
#4
Apr24-14, 05:03 PM
P: 2
Thank you both for the quick answers.
So technically one could say that the quantum numbers are fixed since the minimum is, or more correct can be, defined as [itex]\phi_0=\frac{1}{\sqrt{2}}\begin{pmatrix}0 \\ v\end{pmatrix}[/itex] with v the vacuum expectation value.
Since the fact that H is introduced as the expansion around this minimum as [itex]\phi(x)=\frac{1}{\sqrt{2}}\begin{pmatrix}0 \\ v+H(x)\end{pmatrix}[/itex] , H has to comply with the minimum itself and therefore its quantum numbers should be compatible with the minimum. Is this a correct reasoning ?
Then secondly, after the reparametrization of the Lagrangian due to the expansion around the chosen minimum, a [itex] H^3 [/itex] self-coupling term arrives in the Lagrangian, which comfirms the fact that all the quantum numbers have to be even.
Thanks again ! It feels like my QFT is getting rusty.
Bill_K
#5
Apr25-14, 08:15 AM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
Quote Quote by Vanadium 50 View Post
Which one is the condensate?
andrien
#6
Apr25-14, 09:26 AM
P: 1,020
Quote Quote by Jochent View Post
Hi everyone,
In Standard model Higgs boson is a scalar particle having constructed from potential which respects ##\phi→-\phi##. It is the only scalar particle in SM ( not to be confused with some pseudoscalar particles which we know), hence it transforms even under parity transformation.
It is a scalar particle hence zero value of J. Also to see the C-parity, you can look at one possible decay which is it's decay to two photons. C-parity of a photon is -1, hence C-parity of Higgs boson is ##(-1)^2=1## .
Register to reply
Related Discussions
Is the higgs boson the mediator of the higgs field? High Energy, Nuclear, Particle Physics 31
What does it mean, The Higgs boson is an excitation of the higgs field High Energy, Nuclear, Particle Physics 11
Higgs boson and the future of quantum phyiscs Quantum Physics 4
If the Boson Higgs Boson only exists for >.< long... High Energy, Nuclear, Particle Physics 1
Could it be that Higgs's boson does not exist, but Higgs mechanism does? Beyond the Standard Model 14
