Register to reply
NMEA (GPS) data tracker
by camerart
Tags: data, nmea, tracker
Share this thread:
camerart
#1
Apr25-14, 03:32 AM
P: 3
Hi,
I am making an NMEA (GPS) signal tracker. (NMEA data is sent from satellites, funcubes plus many more objects e,g, animal tracking) and will be used to aim it's antenna toward the signal for better reception. I assume that this is used for telescope aiming also.
The data includes location. Follow the link for information: http://www.gpsinformation.org/dale/nmea.htm
What I am hoping for is a calculation between two of these points. 1/Tracker and 2/target. Is anyone willing to help me please?
Cheers, Camerart.
Phys.Org News Partner Astronomy news on Phys.org
Image: Chandra's view of the Tycho Supernova remnant
Bright like a diamond: lasers and compressed carbon recreate Jupiter's core
New mass map of a distant galaxy cluster is the most precise yet
davenn
#2
Apr25-14, 05:09 AM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,492
HI
welcome to PF
not directly in the aiming .... initially its more of a location of the telescope thing
My telescope is a "GOTO" scope. It has a GPS receiver in it and the scope computer uses that data and then the manual location of several bright stars and from that info the computer can locate any object in its database that is currently above the horizon
Pretty cool :)
not sure how to answer that, or if I even can ? do some more clarifying please
what 2 points ? are they both on earth? or is one of them the satellite ?
cheers
Dave
camerart
#3
Apr25-14, 06:07 AM
P: 3
Hi, Thanks.
From what you say, your telescope has a GPS so that it can compare it's location with a database, for the aiming calculation.
I think the difference in what I want is, that the second location is received through an antenna and radio receiver. I need a program to calculate the two locations, to add to a PIC program, so it can tell the two motors which way to move. Very similar to yours.
Cheers, Camerart.
russ_watters
#4
Apr25-14, 06:24 AM
Mentor
P: 22,239
Yes, if you have two sets of lat/long coordinates, you can find the angle and length of a line between them with geometry. That's a basic component of navigation. Googling finds lots of online calculators for it, some that even include a cut-and-past math script to use yourself: http://www.movable-type.co.uk/scripts/latlong.html
Now, pointing the device is not a simple problem because it isn't necessarily easy to know the starting orientation of your device. Have you put any thought into that? How accurate does the pointing need to be?
camerart
#5
Apr25-14, 08:29 AM
P: 3
Quote Quote by russ_watters View Post
Thanks for the link, but as you say it looks to me like two dimensional, I need three (Correct me if I've wrong)
I'm hoping for someone, who can do the calculations, for feedback as my project moves forward.
My device will be aimed according to either visual or previous knowledge, or in the case of animal tracking, it will be scanned around till a signal is received.
The tracker need to be able to keep up with whatever it is tracking, some are faster than others, but the hardware will be built to cater for the calculation speed.
Thanks, Camerart.
Register to reply
Related Discussions
Sun tracker via GPS Electrical Engineering 3
Using Tracker Introductory Physics Homework 0
GPS - Doubt regarding RMC speed value in NMEA files Astronomy & Astrophysics 3
NMEA data to Graphical Output? Electrical Engineering 3
Sun Tracker Mechanical Engineering 15
