Could a planet get heavier without needing to grow in size?
  • Thread starter Toldox
  • Tags
    Planet
In summary, the conversation discusses the possibility of changing the weight or mass of a planet by replacing less dense materials with denser ones. It is noted that this is theoretically possible but not practical, and that the term "size" should not be used to refer to diameter, mass, or other measurements. The concept of "theoretically" is also discussed, and it is explained that replacing materials with different densities can have significant consequences for a planet's atmosphere, magnetic field, and other factors. Ultimately, the conversation concludes that it would be nearly impossible to find enough denser material to replace the less dense materials in a planet, given our current technology.
Toldox
Hi!
Could we (at least) in theory change a planet's weight with denser core material
so that it could be as large as it is, but have increased the gravity to the level like earth?
Astronomy news on Phys.org
the term you want is the objects mass, and yes you could replace less dense material with a higher density material, to increase the mass without increasing the volume. Though probably never practical lol
see the wiki link on mass vs weight
http://en.wikipedia.org/wiki/Mass#Weight_vs._mass
There is a secondary issue. I'm guessing that you are looking for a smaller planet but with the same surface gravity. Reducing the diameter and keeping the mass the same would actually increase surface gravity. So increasing the density is more effective than you might expect.
"Size" should not be used to mean "diameter" or "mass" or "length" or "area" or "volume" or any other such far less ambiguous term. IOW, using the word "size" makes your meaning more difficult to understand.
As a matter of fact, once planets (specifically Gas Giants) get to be the diameter of Jupiter, their diameters increase very little as their mass increases - accumulation of more hydrogen increases their density and has a very small effect on their diameter. That is why if you compare the diameters of Saturn and Jupiter they differ very little while the mass of the two is significantly different.
One of the neat examples of integral calculus is using it to prove that the force of gravity depends on only two things: the distance you are from the center of mass and the amount of mass closer to that center (picture a sphere with you on its surface). This means that if the density of the Earth were constant (it is not), that you would substantially decrease your weight as you dug a hold towards the center of the Earth. In reality, the gravity of Earth increases at first (see Wikipedia) before it drops to zero at the center.
"Theoretically" is another one of those terms which need be used with caution and awareness. The density of the hydrogen in the center of the Sun is (estimated) to be about 110 g/cc and yet we all know that we can use hydrogen gas to lift zepplins because it is so light. Iron's density is about 12 g/cc, so "theoretically" replacing the hydrogen in the Sun's core with iron would decrease the density (and mass) of the Sun! So, the word 'theoretically' can and often does mislead unless you clearly understand what assumptions are being made about the system being discussed and the theory (theories) being used. If we could magically (and isothermally) replace all of the iron, nickel and silicon in the Earth's mantle and core with iridium (one of the densest of the elements) keeping the volume the same, then there would be a large increase in the gravity at the surface of the Earth. Such a magical change would have serious (probably fatal) consequences for us including to the length of the day, our orbit around the Sun, our magnetic field (which protects us from radiation from the Sun and Cosmic Rays), as well as the chemistry of the Earth and the toxicity of lava. Since iron is one sink for oxygen, and silicon is another, such a change could have dramatic long term effects on our atmosphere as well. The Sun is 99.9% of the mass of the Solar System, finding enough denser material to replace the less dense stuff composing some fictional planet would be "theoretically" impossible given our current technology (or any foreseeable future technology).
Yes, it is possible for a planet to get heavier without needing to grow in size. This can be achieved by changing the composition of the planet's core to a denser material, which would increase its overall mass and therefore its gravitational pull. This is similar to how the Earth's core is made of iron, which contributes to its weight and gravity. However, this would require a significant amount of energy and resources, and it is not something that can be easily done in practice. Additionally, altering the composition of a planet's core could have other consequences on its overall structure and stability. Therefore, while it may be theoretically possible, it is not a feasible solution for increasing a planet's weight.
1. What factors contribute to a planet's weight?
The weight of a planet is determined by its mass and the force of gravity acting on it. The more massive a planet is, the greater its weight will be. Similarly, the closer a planet is to its star, the stronger the force of gravity will be, resulting in a heavier weight.
2. Can a planet's weight change over time?
Yes, a planet's weight can change over time. Factors such as meteorite impacts, volcanic eruptions, and atmospheric changes can all contribute to fluctuations in a planet's weight. Additionally, the gravitational pull of nearby objects can also affect a planet's weight.
3. Is it possible for a planet to gain weight without growing in size?
Yes, it is possible for a planet to gain weight without growing in size. This can happen through the accumulation of debris and dust from space, which adds to the planet's mass and therefore increases its weight. Additionally, the planet's atmosphere can also contribute to its weight without changing its size.
4. Can a planet's weight affect its orbit?
Yes, a planet's weight can affect its orbit. The more massive a planet is, the stronger its gravitational pull will be, which can influence the orbit of other objects in its vicinity. This is why larger planets tend to have more moons and other objects in orbit around them.
5. How does a planet's weight impact its overall composition?
A planet's weight can impact its composition in various ways. The heavier a planet is, the more likely it is to have a dense core and a thicker atmosphere, as the force of gravity can hold onto more gases and materials. Additionally, a planet's weight can also affect its geological processes and the types of materials present on its surface.
  • Astronomy and Astrophysics
