Register to reply
Aluminum and iron(III) reaction
by kevinnn
Tags: aluminum, ironiii, reaction
Share this thread:
kevinnn
#1
Apr26-14, 06:10 PM
P: 115
I was not expecting there to be a reaction between aluminum metal and a solution of iron chloride. I thought the aluminum would be oxidized and the iron reduced. What is the reaction that is occurring that is creating hydrogen gas on the surface of the aluminum? I know it has to do with aluminum reacting with the hydronium ions in solution but I can't come up with a balanced equation because i don't know what happens to the oxygen from the water. Thanks.
Phys.Org News Partner Chemistry news on Phys.org
Faster, cheaper tests for sickle cell disease
Simulations for better transparent oxide layers
Characterizing strontium ruthenate crystals for electrochemical applications
SteamKing
#2
Apr26-14, 07:27 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,555
Perhaps you should do some research on iron (ferric) chloride.
http://en.wikipedia.org/wiki/Iron%28III%29_chloride
When it is dissolved in water, it makes an acidic solution. This solution is commonly used as a cheap etchant for making home-made circuit boards. If the solution is strong enough, it will etch metals like aluminum.
Register to reply
Related Discussions
Iron(II) oxide vs iron(III) oxide in a thermite reaction Chemistry 2
Chemical Reaction to pulverize Aluminum? Chemistry 6
Reaction between Aluminum Sulfide and Bleach? Chemistry 6
Which catalyst is the best for the reaction betweeen Aluminum metal and HCl? Biology, Chemistry & Other Homework 1
Any reaction with asphalt and magnetized iron. Biology, Chemistry & Other Homework 2
