Register to reply
Optimal spacing of diffusive sheet between light and destination
by ares
Tags: diffusive, light, optimal, sheet, spacing
Share this thread:
ares
#1
Apr29-14, 08:45 AM
P: 2
Hi,
I have 4 fluorescent tubes in plane A as a light source. Plane B is receives the light and is parallel to plane A. In between I'll put a sanded piece of PMMA in order to scatter the light. Each plane is approximately 250*300 mm. For a fixed distance between A and B, lets say 200 mm, what would be the optimum position of the sanded PMMA in order to achieve maximum light scatter at B? This is all in a closed box of 250*300*200 mm.
If you put the diffusive sheet very close to the light you can clearly make out the seperate tubes which might mean that maximum scatter is not achieved. On the other hand if you place the diffusive sheet against plane B there will hardly be any scatter at all.
Would you say that placing the sheet as close as possible to A is optimal or is the optimum somewhat away from A?
The goal would be to reduce the distance between A and B as much as possible to get a small box while still achieving sufficient scatter.
Thanks in advance for any thoughts you have on this.
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
Greg Bernhardt
#2
May4-14, 10:18 PM
Admin
Greg Bernhardt's Avatar
P: 9,328
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Register to reply
Related Discussions
Optimal fin spacing for natural convection when Nu = 1 Engineering, Comp Sci, & Technology Homework 5
How do i determine optimal temperature and optimal PH level? Biology, Chemistry & Other Homework 1
Understanding Light in a Sheet of Glass General Physics 5
Relationship interatomic spacing or interplanar spacing and grain size Atomic, Solid State, Comp. Physics 5
Ray of light striking a plastic sheet Introductory Physics Homework 9
