Register to reply
Phase diagram BiMnO3
by fahmi amin
Tags: bimno3, diagram, phase
Share this thread:
fahmi amin
#1
May1-14, 09:44 PM
P: 3
HELLO everyone..
i have read some journals and some researchers (not all but most of them) said that bismuth manganate MUST be synthesized in high pressure conditions. in other words, not in room temperature/pressure. it that true? because some of researchers also synthesized that BiMnO3 in normal pressure (i just assumed it as normal pressure@not high pressure because they are not mentioned it in their journals) and use a solgel or solid state rxn method in their BiMnO3 researchs.
which one is ok?
Phys.Org News Partner Physics news on Phys.org
Creation of a highly efficient technique to develop low-friction materials
An interesting glimpse into how future state-of-the-art electronics might work
How computing is transforming materials science research
ZapperZ
#2
May1-14, 09:58 PM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Please get into the habit of citing your sources when posting here, especially when you are using these external sources as the basis of your post and question.
Zz.
fahmi amin
#3
May2-14, 01:39 AM
P: 3
ok.. i'm sorry pal
UltrafastPED
#4
May2-14, 02:58 AM
Sci Advisor
Thanks
PF Gold
UltrafastPED's Avatar
P: 1,908
If you search on "Phase diagram BiMnO3" - you will find that high pressure will stabilize BiMnO3, but that the phase diagram is currently unknown.
Thus your question appears to be an open research question.
DrDu
#5
May2-14, 06:27 AM
Sci Advisor
P: 3,593
Even if that compound wouldn't be the most stable modification at normal pressure does not exclude the possibility that it can be synthesized at normal pressure. E.g. diamond can be deposited by CVD alltough it is a high pressure modification.
Register to reply
Related Discussions
Al-W phase diagram Materials & Chemical Engineering 7
Phase diagram Classical Physics 2
PV phase diagram? Mechanical Engineering 0
Sn-Pb phase diagram Biology, Chemistry & Other Homework 7
Phase diagrams, ternary phase diagram Materials & Chemical Engineering 0
