Register to reply
Effect of Atmospheric seeing
by omthegreat
Tags: atmospheric, effect
Share this thread:
omthegreat
#1
May3-14, 03:42 AM
P: 2
This is probably a stupid question, but it has been bugging me.
We are severely limited in ground based observations due to atmospheric seeing effects distorting the image. Why then are we not concerned by the vast amounts of gas/planets/etc in the line of path to our source that should also introduce a seeing effect?
Is it just that the densities of these intervening gas clouds are so low that scattering is negligible and intervening planets are too small to have an impact?
Phys.Org News Partner Astronomy news on Phys.org
Magnetar discovered close to supernova remnant Kesteven 79
Image: Hubble looks at light and dark in the universe
Mixing in star-forming clouds explains why sibling stars look alike
mfb
#2
May3-14, 11:21 AM
Mentor
P: 11,925
  • Stars, planets and all other dense objects are tiny compared to the empty space in between. If you look in a random direction in the sky, it is unlikely that any object is there (until you reach the CMB).
  • The further away a gas cloud is, the larger the volume where "your" light goes through. That makes small-scale effects negligible - apart from the atmosphere of earth.
  • With a typical density of something like 100 atoms/cm3, you need of the order of 100 000 to 1 million light years to get the same area density as our atmosphere.
Tobychev
#3
May7-14, 06:38 PM
P: 7
We are concerned with the intermediary gas, but not with respect to seeing. The effect of interstellar gas basically distorting the spectrum we observe, calling the "reddening". I guess there could be seeing effects from the interstellar gas, but we are pretty far from that beeing a real concern, the turbulence in interstellar clouds is probably on much bigger scales than the apparent size of the objects we study.
Register to reply
Related Discussions
Atmospheric pressure effect on simple mechanisms Mechanical Engineering 6
Atmospheric siphon effect General Physics 17
Effect of freefall on hydrostatic/atmospheric pressure General Physics 8
Temperature - Effect on atmospheric pressure. Astronomy & Astrophysics 13
Effect of Atmospheric pressure on Butane /propane General Physics 0
