| Thread Closed |
An "invisible wall" created by static electricity? |
Share Thread | Thread Tools |
| May11-05, 08:53 AM | #1 |
I copied below a post to sci.astro on a strange phenomenon involved with high-voltage static electricity. It concerns the creation of an "invisible wall" due to electrostatic charge from a large sheet of polypropelene film moving at high speed at a 3M plant:
David Swenson's electrostatic "invisible wall". http://amasci.com/weird/unusua*l/e-wall.html A perhaps related phenomenon is illustrated by this experiment on Hero's Fountain: Expt 013 -- Hero's Fountain. http://chemmovies.unl.edu/chem*istry...mos/BD013.html Here, a electrostatically charged balloon held near a Hero's Fountain causes the fountain to dissipate. See the video at the link in step #4 in the Procedure section. In the post to sci.astro, I suggest the effect at the 3M plant was due to the effect electrostatic charge has on polar molecules such as water. What would really seal this would be to see if the same "invisible wall" was observed to effect materials composed of non-polar molecules. I would like to be able to estimate the possible force produced on a polar molecule such as water by an electrostatic charge and what would be the magnitude of the electrostatic voltage created by a Van de Graaff generator dependent on its dimensions. Anyone know of any such formulas for this? Bob Clark ************************************************** Newsgroups: sci.astro, sci.physics, sci.engr.mech, sci.space.policy, sci.chem From: "Robert Clark" <rgregorycl...@yahoo.com> Date: 10 May 2005 10:30:30 -0700 Local: Tues,May 10 2005 1:30 pm Subject: Re: An "invisible wall" for ground-based scopes.[Re: An atmospheric envelope for ground-based telescopes.] George Dishman wrote: > <rgregorycl...@yahoo.com> wrote in message > news:1115572029.828589.36910@z14g2000cwz.googlegroups.com... > > George Dishman wrote: > >> "Robert Clark" <rgregorycl...@yahoo.com> wrote in message > >> news:1115565190.846069.40280@f14g2000cwb.googlegroups.com... > >> > Astronomers like to wring every last photon from their observations so > >> > having a physical cover at the top of the shroud may be problematical. > >> > The tapered tower providing constant pressure with altitude idea is > >> > also problematical. > >> > So after a web search I was interested to see this report: > >> > David Swenson's electrostatic "invisible wall". > >> > http://amasci.com/weird/unusua*l/e-wall.html > The page you quote is entirely speculative, they > didn't actually find out what caused the effect. > I know of a situation where there was a single > turn of wire on the ground. Someone walking along > put one foot in it and found he couldn't move. > The coil undergoing a short circuit test and was > carrying several thousand amps DC. It wasn't a > direct force effect, the field was numbing the > nerves in the guys legs. There are many > possibilities in the case of the 3M effect and > until they figure it out, reproduce it and find > out how to control it you are wasting your time. > ... That the phenomenon observed was a true effect is suggested by electrostatic experiments such as these: J4-12: ELECTROSTATIC FORCE - MOVING LUMBER. PURPOSE: To demonstrate polarization of water molecules. http://jedlik.phy.bme.hu/~hartlein/p...cdem/j4-12.htm This is from a page of undergraduate physics experiments. It demonstates the effect of electrostatic charge on polar molecules such as water. A piece of lumber is made to rotate over a low friction support by bringing close a rod charged with static electricity by rubbing with a wool cloth. The effect arises from the polar molecules of water in the wood. This is effect is also illustrated by this experiment: J4-11: POLAR AND NONPOLAR LIQUIDS PURPOSE: To demonstrate that non-uniform electric fields produce a force on polar molecules. http://jedlik.phy.bme.hu/~hartlein/p...cdem/j4-11.htm Here a stream of water is deflected by a source of electrostatic charge while a stream of carbon tetrachloride (CCl4), a non-polar molecule, is not. The static charge built up on a rod or a balloon by rubbing with a cloth amounts to perhaps a few thousand volts. Dave Swenson in the phenomenon observed at the 3M plant estimated the static electricity was in the megavolt range. Human beings and all living beings are composed of mostly liquid water. Then considering the deflections of water at a few thousand volts in these lab experiments, it is conceivable that voltages a thousand times higher could have the effect observed at the 3M plant. If this is the explanation then this "invisible wall" would work against human beings and other living things but not inanimate objects that did not contain water. However, it is known that large Van de Graaff generators can produce static voltages in the megavolt range: Construction of the Van de Graaff Generator. http://www.mos.org/sln/toe/con*struction.html Have experiments been done on the effect of such large generators on large amounts of water? Note that with this explanation of the 3M plant phenomenon it wouldn't work to create an invisible wall around our telescope because it wouldn't effect the non-polar molecules in the air. The method of ionizing the air with lasers might still work though. Bob Clark ************************************************** |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| May11-05, 08:58 AM | #2 |
This board sometimes inserts asterisks arbitrarily in links.
Here the corrected links: David Swenson's electrostatic "invisible wall". http://amasci.com/weird/unusual/e-wall.html Expt 013 -- Hero's Fountain. http://chemmovies.unl.edu/chemistry/beckerdemos/BD013.html Construction of the Van de Graaff Generator. http://www.mos.org/sln/toe/construction.html Bob Clark |
| May13-05, 02:19 AM | #3 |
I've been here for a while, and I've never ever seen the astrerisks before! That's strange. Anyone have an explination for it?
| May13-05, 08:32 AM | #4 |
In the 3M phenomenon, there appears to be a repulsive effect.
I presume there is also a repulsive effect here in this case as well: Expt 013 -- Hero's Fountain. http://chemmovies.unl.edu/chemistry/...mos/BD013.html since in the video the fountain is made to stop when the charged balloon is brought close to the stream. But this page says a stream of falling water will be *attracted* to a charged balloon: Lesson 1: Charge and Charge Interactions Polarization. http://www.glenbrook.k12.il.us/gbssc...ics/u8l1e.html Also curious is what this page on this experiment says of it: J4-11: POLAR AND NONPOLAR LIQUIDS. "NOTE: Although the demonstration apparently works as predicted, this demonstration does not work according to theory, and should probably not be done and explained in the traditional manner." http://www.physics.umd.edu/lecdem/se...osj4/j4-11.htm And in this video version of the moving lumber experiment, the lumber is *attracted* to the charged rod whether it is charged positive or negative: Question #131 http://www.physics.umd.edu/lecdem/ou...arch7/q131.htm Bob Clark |
| May13-05, 01:00 PM | #5 |
Thoughts:
I've done some reading about electrostatic motors like the ones Ben Frankin made. They generally work on the principle that some element of the rotor is first attracted to an opposite charge, approaches closer, then becomes similarly charged itself and is repelled. I would think this "wall" is the same thing. The workers meet a sudden resistance when they get close enough to become charged to the same polarity as the film. I don't think the wall has anything to do with water molecules. In fact the link is pretty clear that the effect was not present during times of high humidity. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: An "invisible wall" created by static electricity?
| Difference between "Identical", "Equal", "Equivalent" | Calculus & Beyond Homework | 9 | ||
| Current Electricity: Help understanding concept of "potential energy" | Introductory Physics Homework | 18 | ||
| Re: What does it mean that "Pc 523 or Dw 868.4" in Smythe, William R. 's <Static and dynamic electricity> | General Physics | 1 | ||
| Who created the "Crunch Theory" and the "Continual Expansion Theory"? | General Astronomy | 3 | ||
