Radioactive Decay: Finding the Half-Life of K-40 in KCL
The discussion focuses on calculating the half-life of the radioactive isotope K-40 in a 2.71g sample of KCl, which decays at a rate of 4490 Bq. The correct half-life is established as 1.25 billion years, derived from the decay constant calculated using the formula [lambda] = decays per second / number of atoms. Participants confirm that the number of K-40 atoms in the sample is approximately 2.560 x 10^20, and emphasize the importance of unit conversion from seconds to years for accurate results.
  • Understanding of radioactive decay and half-life concepts
  • Familiarity with the decay constant formula [lambda] = decays per second / number of atoms
  • Basic knowledge of logarithmic functions, specifically natural logarithm (ln)
  • Ability to perform unit conversions, particularly from seconds to years
  • Study the principles of radioactive decay and half-life calculations
  • Learn about the decay constant and its significance in nuclear physics
  • Explore logarithmic functions and their applications in scientific calculations
  • Investigate the implications of radioactive decay in geological dating methods
This discussion is beneficial for physicists, chemistry students, and anyone interested in nuclear science, particularly those studying radioactive isotopes and their decay properties.
JingXionG
A 2.71g sample of KCL is found to be radioactive, and it is decaying at a constant rate of 4490 Bq. The decays are traced to the ekement potassium and in particular to the isotope K(proton number 40), which constitutes 1.17% of normal potassium. find the half-life of this nuclide( Take molar mass of KCL = 74.555g)
Ans provided is 1.25 x 10^9 years. I can't seem to even come close to that value.
I found the number of K-40 in the sample which is 2.560 x 10^20. From there, using A= constant x number of particles of K-40 and rate of decay = -dN/dt, I can't seem to get that ans
I think you're on the right track here. Your number for the number of 40K atoms is very close to what I got.
My next step was to find the decay constant, [lambda]. If the rate of decay is constant, then
4490 Bq = 4490 decays per second. Once you have [lambda], you can use
T1/2 = ln(2) / [lambda] to get your half-life in seconds. I get 3.95 x 10 16 seconds, which is equivalent to 1.25 Billion years.
I should add a word of caution that this is *not* a completely rigorous method. You can't use it for something with a half-life of, say, 15 seconds. However, since the problem states the decay rate is constant and you can see that the decays/second are << than the number of atoms in the sample (16 orders of magnitude in this case), it should get an accurate answer.
argh
i know where i went wrong, forgot to convert the seconds to years!
