Register to reply
Analyzing the thermodynamics of a hot tub
by olafurjt13
Tags: analyzing, thermodynamics
Share this thread:
olafurjt13
#1
May6-14, 03:05 PM
P: 1
Hi everyone,
I'm working on a project at my university and I'm having trouble figuring out how much heat escapes a hot tub when it's at 42C and outside temperature is at around 7C (I live in Iceland).
I'm considering the hot tub closed with a styrofoam cover about 10cm thick and walls of the same material.
Any advice on how to calculate the heat transfer from the tub?
The size of the tub is 2,35 x 2,35 x 0,98 m
Phys.Org News Partner Engineering news on Phys.org
Greater safety and security at Europe's train stations
Fingerprints for freight items
On the way to a safe and secure smart home
mfb
#2
May6-14, 05:03 PM
Mentor
P: 11,928
If the styrofoam cover would be perfect, with the regular heat conduction equation. You might need some approximations for the edges and corners (like "just ignore them") if you want to avoid numerical simulations.
In reality, you also have to consider losses between the cover and the wall. This could be a significant part of the total loss.
russ_watters
#3
May6-14, 08:36 PM
Mentor
P: 22,305
So start by looking-up the insulation value for styrofoam and making sure you understand how to use it.
Register to reply
Related Discussions
Analyzing a Circuit with an Op-Amp Engineering, Comp Sci, & Technology Homework 2
Help analyzing an RC circuit? Engineering, Comp Sci, & Technology Homework 10
Analyzing a BJT using pi-model General Physics 1
Analyzing the bus General Math 3
Analyzing a wave Introductory Physics Homework 7
