Rock on stringsstuck on last part of problem
  • Thread starter Thread starter Rockdog
    Rock
The problem involves a rock being whirled on strings, focusing on the forces acting on the rock and the maximum speed it can achieve before the strings break. The subject area includes concepts from circular motion and tension in strings, with specific attention to centripetal force calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of centripetal force equations and the geometry of the situation, including the use of triangles to determine components of tension. There is exploration of different methods to calculate the maximum speed, including consideration of angles and forces acting on the rock.
Some participants have confirmed the correctness of earlier parts of the problem and are engaged in a detailed examination of part d. There is an ongoing debate about the correct use of trigonometric functions to resolve the components of tension, with suggestions to utilize similar triangles for clarity.
Participants are working under the assumption that gravity can be neglected, and there is a focus on the geometry of the setup, including the angles formed by the strings and the rock's motion. The maximum tension in the strings is a critical constraint in the calculations.
Rockdog
Picture is attached as follows:
A 480 gm rock is whirled on the end of a string 47 cm long which will break under a tension of 27 N.
a) What is the highest speed the rock can reach before the string breaks? (Neglect gravity.)
b) If two other strings identical to the first were attached to the rock, how fast could the rock be whirled before the three strings would break?
Next the rock is held by two of the same 47 cm strings with ends 56 cm apart and whirled in a circle between them. Neglect gravity.
c) What is the radius of the circle of motion?
d) Now what is the maximum speed the rock can have before the string breaks?
I'm stuck on part d, but I can go over a-c. Maybe that might help me solve c.
a) Well, the first thing I did was convert grams to kilograms and cm to meters. Then by using this equation, F=(m*v^2)/R
where F=force
m=mass
v=velocity
R=radius, i get V=5.14 m/s
b) Same equation as above, except force now equals 81N (3*27)
answer is 8.91 m/s
c) This I drew a triangle. Since it is isoceles, I figured out that height (radius) = sqrt(47^2-.25*56^2) =>37.7 cm as my radius.
d) Here I'm stuck. I know I can use the centripetal equations: a=v^2/R or F=(m*v^2)/R, but how to go about it I'm unsure about it.
I did draw a triangle, where the hypothenuse was 47, the base is 37.7 cm..and since two angles are 70 and 90 degrees, the last angle is 20 degrees. So I did 47 sin 20 to get the x component, which turned out to be 16.07 cm. Whether this can be of any use to me, I don't know. The hint tells me to break the tensions into their components, but then what?
Yes, parts a- c you have done correctly.
d is difficult. Once again, the centripetal force in toward the center of the circle is given by "F=(m*v^2)/R" as you had before.
However, now you have two strings holding the rock, at an angle.
If you drew a picture, then you saw that you have two right triangles. The hypotenuse of each right triangle is 47 cm long. The "base" is 56/2= 28 cm long and so the "opposite" side has length √(472-282) cm= 37.7 cm approximately, just as you got before.
Now, each string will support half of the "m*v^2/R"= (0.48/0.377)v2= 1.27 v2.
That is, the opposite side of the "force" triangle will be 1.2 v2. The hypotenuse of that triangle will be the tension in the string. Using "similar triangles", we can set up:
T/(1.2v2= 47/37.7 or T= 1.2v2(47)/37.7= 1.52v2. Set that equal to the maximum value for T: 27 N and solve for v.
Ok, so the three sides of the triangle are hyp = 47, x = 28, and y = 37.7. So what i did was do inverse sin of 28/47 or inverse cos of 37.7/56, and got the top angle (the angle between the string and the center-pointing tension force) to be 36 degrees. From there, I took the vertical component of the 27 N tension force, 27cos36, and got the vertical component of one string to be 21 N. I then multiplied this by two because there are two strings, and got 42, and used this as the tension. You set Fc = Ft, and I got the terminal velocity to be 5.7 m/s.
No, the vertical component is 27 sin(36.7) not cosine.
Since you just used sin(θ)= 28/47 it is simpler to use similar triangles, as I suggested, to arrive at that (trigonometry is just a complicated way of working with similar triangles!).
Um. I think in this situation, the 36 degrees is made from the vertical axis, so the vertical component would be found using cosine.
edit: in my picture I have the two strings being held from points separated horizontally, and the rock is traveling in a vertical circle (but without gravity)
I agree that using similar triagle is eassier as it avoids this confusion.
  • · Replies 22 ·
  • · Replies 16 ·
