Unraveling the Meaning of t = 0 in Physics
  • Thread starter Amad27
  • Tags
    Physics
In summary: Basically an arbitrary time that has no physical meaning.ThanksI can sort of see where you are getting at.The device DOESNT start at t = 0, but rather some infinitesimal time after that? Devices starting at t= 0 is just an assumption in the mathematical world? So because it doesn't actually start at t = 0, you get the error right?
Amad27
412
Hi,
It is a mystery that is complicated to figure out.
What does t = 0, (time 0) actually mean in Physics?
Suppose a device's rate of processing is modeled by
Q(t) = 467√(t) [where "t" is the time in minutes after the device began working]
Why is the instantaneous moment when the device began working t = 0?
In addition, what would
"0 minutes after the device began working" mean? What does this represent?
Thanks
It's when you press start, or when the engagement mechanism is released.
In general it is an arbitrary point on the time scale which corresponds to your beginning of the process of interest ... like in a count down, but going in the opposite direction.
Amad27 said:
Hi,
No great mystery here, just convention. No special physical meaning. What does have meaning is the amount of time elapsed--which is easier to represent if you start from 0.
Because you want to measure the elapsed time from the moment the device began working. You could call that time Ti, if you like. But then you'd have to describe your model in terms of T - Ti, to get the time since the device began working. Much easier to let Ti = 0.
It just represents the instant that the device began working. Nothing more.
You can chose t = 0 to be any time whatsoever. It's an arbitrary choice made to our convenience. The idea is to make a choice that helps understand the problem and solve it. A different choice might be more difficult but it won't be wrong.
How would you force the device to start at t = 1?
But think about this, WHY does it even start at t= 0
Once you turn the device on, at least 1 trillionth of a trillionth of a trillionth of a picosecond must have passed? Some very small infinitesimal time MUST have passed right?
Thanks
It's an idealization in the experimental world - part of my research was to experimentally find the "time zero" which was defined as the "time when a laser pulse passed through an electron pulse"; with the expenditure of time, ingenuity, and sweat a repeatable experimental technique was developed - it was good to less than a picosecond; the limitation was about double the pulse duration.
The "error" then contributes to the experimental spread.
But for a theoretical model you can just set t=0; a mathematical analysis will tell you the amount of error which will accumulate for small, random variations.
This could mean that
it could have start at t =
1 Planck time of 1 Planck time of 1 Planck time...
You are SERIOUSLY over-thinking this. t=0 is a mathematical ideal as has been explained. Depending on the characteristics of a physical device, its actual "start" time will be some amount of time later. SO WHAT? You have to assign some value to the start and as long as you are consistent, it doesn't really matter.
Thanks
Do you also have a problem with following a recipe? If the recipe tells you to bake the cake for 45 minutes, how much do you over-think this? Or do you simply put the cake into the oven, and then start your timer or look at your clock?
Zz.
you can say t=0 the time that it actually starts to to work- problem solved.
No matter what, what is important is the elapsed time, and not a single instant time (you need two ("tick tack") to measure time, not just one ("tick")...)
After that it depends on your MEASUREMENT device- how close together are the "tick tacks" it can realize... speaking of Planck time for example, for any device we have, is totally meaningless...Don't forget that the clocks we use, are using some process to measure time (eg atomic clocks), so even they measure "time differences" and not instant time values...
Are we still talking about this?
Amad27, the choice of origin for the time coordinate is completely arbitrary and we can chose it to be whenever we want. I may chose the time the device stars to be 0, 1 Plank time, 1 billion years, whatever I want... t=0 seems like a simple choice. Why not go with?
The model for the device's rate of processing is probably invalid near t=0.
1. What does t = 0 represent in physics?
t = 0 represents the starting point or initial time in a physical system. It is often used as a reference point for measuring time and determining the evolution of a system.
2. Why is t = 0 important in physics?
t = 0 is important because it allows us to establish a standard reference point for measuring time and analyzing the behavior of a physical system. It helps us understand the initial conditions and how they affect the future behavior of the system.
3. How is t = 0 determined in physics?
t = 0 is determined based on the specific context of the physical system being studied. It could be determined by a specific event, such as the start of an experiment, or by a pre-defined standard, such as the beginning of a time interval on a measurement device.
4. Can t = 0 change in different physical systems?
Yes, t = 0 can change in different physical systems. It is a relative measurement and can be defined differently depending on the context. For example, the start of a chemical reaction may be t = 0 in one system, but the start of a motion may be t = 0 in another system.
5. How does t = 0 relate to other variables in physics?
t = 0 is often used in conjunction with other variables, such as position, velocity, and acceleration, to analyze the behavior of a physical system. It helps establish a starting point for these variables and allows us to track their changes over time.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
