Register to reply
Considering a circle to be an infinite sided n-gon
by acesuv
Tags: circle, infinite, ngon, sided
Share this thread:
acesuv
#1
May9-14, 08:55 PM
P: 55
as a regular polygon increases in sides, it becomes rounder. As you increase the number of sides, the polygon will tend towards a perfect circle but never quite make it. you can only make the circle with an infinite number of sides - stopping at any other number but infinity you will only get a very very very round but noncircle shape. but you know all this...
IS IT APPROPRIATE TO CONSIDER A CIRCLE A REGULAR POLYGON WITH INFINITE SIDES? ARE THERE ANY DISCREPANCIES IN CONSIDERING A CIRCLE A REGULAR POLYGON?
also I am wondering... technically a circle must have vertices of 180 degrees, right? is this a discrepancy?
Phys.Org News Partner Mathematics news on Phys.org
Researcher figures out how sharks manage to act like math geniuses
Math journal puts Rauzy fractcal image on the cover
Heat distributions help researchers to understand curved space
HallsofIvy
#2
May10-14, 07:00 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,691
A polygon, by definition, must have "n" sides and "n" angles for some integer n. "Infinity" is not an integer so you will have you will have to specify what you MEAN by "A REGULAR POLYGON WITH INFINITE SIDES". Once you have done that, perhaps someone can answer.
micromass
#3
May10-14, 10:12 AM
Mentor
micromass's Avatar
P: 18,345
Quote Quote by acesuv View Post
A polygon has by definition a finite number of sides. So a circle is not a polygon.
It is certainly true that a circle is (in some sense) a limiting value of polygons and this fact is extremely useful. But that doesn't mean that the circle is a polygon. In the same way, the number ##0## is a limiting value of ##0.1##, ##0.01##, ##0.001##, ..., but all these numbers are positive while ##0## is not. So a limiting value does not need to have the same properties as the elements of the sequence.
The ancient Greeks might have considered the circle a polygon with infinite sides, but this is not done anymore. One of the reasons why not is that we have not really defined what a "polygon with infinite sides" is. Furthermore, the notion can be confusing to people, so we choose not to use it.
acesuv
#4
May10-14, 03:54 PM
P: 55
it seems, to me, arbitrary that a circle is not a polygon because the definition of a polygon is finite sides. perhaps im not grasping this, but if we changed the definitions around a little couldnt we fit a circle into the same category as regular polygons?
dont get me wrong, im not on some crusade to get circles to be considered regular polygons... im just very interested in the idea that you COULD categorize a circle in with the rest of the regular polygons
im really looking for something bulletproof like the angles of a circle must be 180 degrees and thats impossible and thats why a circle cant be a regular polygon. not just "our definitions dont quite allow that"
sorry if im being ignorant but i cant help it :p
acesuv
#5
May10-14, 03:59 PM
P: 55
Quote Quote by HallsofIvy View Post
i mean what if you keep adding sides and sides and sides to a regular polygon so it goes from triangle to square to pentagon to septagon octogon etc into infinity
i think im being very straightforward with this question?
micromass
#6
May10-14, 04:01 PM
Mentor
micromass's Avatar
P: 18,345
A definition is always a bit arbitrary.
What would you propose as definition then?
You can't prove or disprove definitions. We can define a polygon in whatever ways we want. We have now defined it as something with finitely many sides. Other definitions might allow other things. So the answer "Our definitions don't allow it" is the only answer we can give.
AlephZero
#7
May10-14, 04:55 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,298
"Infinity" is not a number. However many sides you add, you still have a polygon with finite number of sides.
acesuv
#8
May11-14, 12:19 AM
P: 55
Quote Quote by AlephZero View Post
well yeah if you stop at any integer youre just going to end up with a very round polygon... you need to go on forever (infinity)
to be it seems straightforward that if you imagine what would happen if a polygon had infinite sides itd be perfectly curved no matter how close u zoomed in while a polygon with finite sides might look round from far away, but you get closer and u see the angles
acesuv
#9
May11-14, 12:23 AM
P: 55
Quote Quote by micromass View Post
thanks for the reply. as a definition for polygon is a shape with multiple sides. is there a particular reason the definition is so specific as to say finite sides? im quite interested
a circles definition is: the set of points equidistant to a single point. this is an infinite set of points. each point is a vertice, is it not?
pwsnafu
#10
May11-14, 12:41 AM
Sci Advisor
P: 839
You need find a proper definition of "side". The only way I can think of defining that would start with is "a side is a straight line such that..." But circles have no straight lines.
A vertex is a point where two straight lines meet. Again circles have no straight lines.
disregardthat
#11
May11-14, 08:51 AM
Sci Advisor
P: 1,810
Toying with definitions, you could just say each "side" of the circle as a polygon has length 0, with initial and end point in the same vertex, for every point on the circle. I don't see the point of this though.
gopher_p
#12
May11-14, 11:22 AM
P: 508
You use phrases like "into infinity" and "go on forever" in regards to the proposed limiting process that leads to what you're calling a regular polygon with infinite sides. This leads me to believe that the object that you're proposing has countably many sides, since the countable cardinal is the limit of the finite cardinals. I reckon you'd say that each side of your infinite-sided polygon has length 0, in which case the perimeter of your object must also be 0.
disregardthat
#13
May11-14, 11:48 AM
Sci Advisor
P: 1,810
Quote Quote by gopher_p View Post
What are the sides then, you mean?
gopher_p
#14
May11-14, 01:20 PM
P: 508
Quote Quote by disregardthat View Post
It's the OP's construction, not mine. I'm only commenting on the number of sides proposed and making a reasonable guess as to what length a side might have, not what constitutes a side.
jbunniii
#15
May11-14, 01:37 PM
Sci Advisor
HW Helper
PF Gold
jbunniii's Avatar
P: 3,289
There are many cases where an object obtained as the limit of a sequence of other objects does not share the same properties as those objects.
For example, the limit of a sequence of continuous functions may be discontinuous. No one would suggest calling it continuous just because it is the limit of a sequence of continuous functions.
So it's not clear to me why you want to call a circle a polygon just because it can be considered as a limit of a sequence of polygons.
disregardthat
#16
May11-14, 03:09 PM
Sci Advisor
P: 1,810
These kinds of guesses are dangerous and rarely reasonable (if we really knew what we were talking about here). For example, the limiting function of a sequence of functions with countably many discontinuities may have uncountably many discontinuities.
HomogenousCow
#17
May11-14, 04:42 PM
P: 366
We should have an FAQ for this, similar threads pop up every week.
acesuv
#18
May11-14, 11:31 PM
P: 55
Quote Quote by pwsnafu View Post
it works if straight lines are infinitely small but nonzero :0 from what i figure like 0.00000000000000infinity1
Register to reply
Related Discussions
Epsilon-delta proof of one sided infinite limit. Calculus & Beyond Homework 3
Help change 6-sided dice circuit to 20-sided Electrical Engineering 2
One sided noise spectral density VS double sided noise spectral density General Engineering 1
The circle with center infinity with infinite radius is the point zero on the complex Calculus & Beyond Homework 0
Circle has infinite sides how many sides does a semi circle have? General Math 3
