Reading open source software code
The discussion revolves around techniques for reading and understanding open source software code, specifically focusing on the Emacs codebase. Participants explore methods for navigating complex code and the challenges faced by newcomers in grasping the original source code before modifications.
  • One participant expresses confusion about how to effectively read and modify open source code, particularly Emacs, and seeks suggestions for improvement.
  • Another participant emphasizes the importance of common coding practices and the code development cycle for understanding software collaboratively.
  • A participant questions the meaning of "reworked" in the context of open source software.
  • One reply suggests that understanding a new project requires communication with current developers and a systematic approach to reading header files and tracking function flows.
  • Another participant shares a technique involving the use of profilers, breakpoints, and trace messages to identify key functions and understand their interactions within the software.
  • It is noted that understanding a large codebase like Emacs can take significant time, varying from days for professionals to months for novices.
  • Participants mention the value of taking notes and utilizing mailing lists, but caution that prior research is necessary to receive helpful responses.
Participants do not reach a consensus on a single technique for reading open source code, as multiple approaches and perspectives are presented. There is recognition of the challenges involved, but no agreement on a definitive method.
Some limitations include the varying levels of experience among programmers and the complexity of different projects, which may affect the applicability of suggested techniques.
Individuals interested in contributing to open source projects, particularly those new to reading complex codebases, may find the discussion valuable.
Eus
Hi Ho! ^^v
I know that open source software can be reworked by many people.
Because of that, it grows rapidly.
Frankly, I wonder how people can rework it if they don't have a good technique in reading the source code.
When reading Emacs source code, I really confused from where I should work.
How about if I want to know what the original source code before any modification is? Is there any way to figure it out?
Is there any suggestions regarding this problem?
Thank you very much! ^_^
Computer science news on Phys.org
I think the "code development cycle" and "coding practices" are the things that are kept common so that all developers can understand each other.
what do "reworked" mean ?
Eus said:
Hi Ho! ^^v
I think you are looking at this wrong. You expect professional programmers to be able to open a project like EMACS up and immediatly know what is going on. That never happens. Generally, a programmer new to a project will talk to programmers currently involved in the project. The new programmer will sit down with a pad a paper and a pencil and read through the header files (the .h files) to understand what functions are found inside and to see what inputs and outputs each function needs and returns. The new programmer will take a lot of notes while tracking the flow of the new project. The new programmer will not simply sit down and open up EMACS and understand what is going on.
This is true for large projects and small projects. If I were to read through a new project I'd do as I described above. Even if it was a small project or I was only working on a small portion of a larger project the above must still be followed. No one can sit down and immediatly know where to begin on a new project.
Reading through EMACS and understanding everything could take a few days or even weeks for a professional to a few months for a novice.
This is my technique. Your mileage may vary.
I use profilers and break points. Additionally most software trees also have a mechanism for generating trace messages (you just have to look through the docs to find the right switch or compile constant). Use the profiler and trace mechanism to run the program you are interested in under a couple of typical scenarios. Find out which functions are most heavily involved (require the most time, called most often) and understand them first. You can use this technique to find out what functions compose what subsystem and which functions call each other.
Next, if the system is really large run the process under a debugger, or attached a debugger to a running process, and put some break points in the section of code you are most interested in (say for instance emac's buffer switching mechanism). Upon the break, view the stack to understand how/why this function is called. Step the function to help understand what it does.
Then you should be reasonably familiar with whatever subsystem you need to modify to add/enhance your feature. NOTE: you do not need to understand the entire source tree!
As faust9 suggests, take notes and mailing lists are valuable resources. But only if you do your homework beforehand. If you ask a general question you will most likely only receive unhelpful or insulting replies.
  • · Replies 40 ·
  • · Replies 52 ·
  • · Replies 24 ·
11K
