Register to reply
Calorimetry CuSO4 question
by Austin
Tags: calorimetry
Share this thread:
Austin
#1
May17-14, 02:01 PM
P: 10
If I am doing calorimetry, I know that if I put something like CuSO4 in water it will dissociate and the water will change temperature...
But if I put something insoluble such as BaSO4 in water, will the temperature still change and will I be able to find it's heat of formation.
It's probably an obvious answer I just don't remember, thanks!
Phys.Org News Partner Chemistry news on Phys.org
Marine pest provides advances in maritime anti-fouling and biomedicine
Nature inspires a greener way to make colorful plastics
New catalyst converts carbon dioxide to fuel
mfb
#2
May17-14, 02:24 PM
Mentor
P: 11,629
If there is no chemical reaction, there is nothing that could change the temperature. Okay, you still have the mechanical energy of the material sinking to the bottom, but that is completely negligible.
Yanick
#3
May17-14, 02:25 PM
P: 380
The temperature may change just from the physical contact between the solid and liquid simply through conduction of heat. In general correlating temperature changes with chemical or physical processes requires knowledge about what processes are occurring during the temperature change. If there is no chemical or physical process occurring then the temperature change is not giving you information about that process.
Also heats of formation refer to compounds being formed from their constituent elements, not being dissolved or dissociated in solution. These values are typically tabulated as standard heats of formation in various thermodynamic tables.
Register to reply
Related Discussions
Calorimetry Introductory Physics Homework 0
Ice Calorimetry Biology, Chemistry & Other Homework 3
Aluminum calorimeter problem Introductory Physics Homework 5
Problems dealing with calorimetry Introductory Physics Homework 2
What is the final temperature of the contents of the container? Introductory Physics Homework 7
