View Poll Results: This is my first post, How do you think I did?
Good job, keep expanding your content. 0 0%
Pretty good, but the topic is lacking. 0 0%
Lacking but ok for a nubie. 0 0%
Meh, Work on it. (Please leave a suggestion) 0 0%
That sucked, like the black hole your talking about. 1 100.00%
Kill your post and your self, (Really bad) 0 0%
Voters: 1. You may not vote on this poll
Register to reply
Black Hole Ideas
by JimmySersland
Tags: black, hole, ideas
Share this thread:
JimmySersland
#1
May17-14, 06:49 PM
P: 1
(Correct me if you think i'm wrong in anyway, I am open to new ideas.) A black hole is created when a planetary mass has its atoms completely cave in on its self. This creates a massive amount of gravity, one so massive that it even attracts photons (light). So does this mean that a black hole isn't black but completely lacking any color at all? I think so. Here's something that I think is cool to think about (your thoughts requested no matter ;) how ridicules), If a black hole begun to suck a sun into is gradational pull
A. Would the pull of the sun pull the black hole any distance?
B. The sun being sucked in, collapsing the atoms(?), would increase the size of the hole(?)
C. What if we, our own solar system, is a black hole and our own physics are much different then the outside of our "realm".
D. Referring to C. Would that mean that the matter in a black hole could also be 99.99% free space?
Phys.Org News Partner Astronomy news on Phys.org
Magnetar discovered close to supernova remnant Kesteven 79
Image: Hubble looks at light and dark in the universe
Mixing in star-forming clouds explains why sibling stars look alike
Bobbywhy
#2
May17-14, 07:32 PM
PF Gold
P: 1,909
You specify a "planetary mass" forming a black hole. You may check the Wikipedia entry at
http://en.wikipedia.org/wiki/Black_hole
to find the common classification of black holes according to their mass.
“Black holes are commonly classified according to their mass, independent of angular momentum J or electric charge Q. The size of a black hole, as determined by the radius of the event horizon, or Schwarzschild radius, is roughly proportional to the mass..."
Several other questions you asked about are also addressed in the Wiki entry.
A. Gravitational attraction between two masses follows a simple relationship, always the same whether masses of black holes or any other kind of mass.
B. A black hole's size is measured by it's "event horizon". Adding mass increases it.
C. "What if we, our own solar system, is a black hole"? is a question that does not make any sense. Can you revise or rephrase it while keeping real black hole physics in mind?
D. Same as above.
Simon Bridge
#3
May17-14, 07:47 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,962
Welcome to PF;
Quote Quote by JimmySersland View Post
No - it takes much more than a planetary mass.
No - the gravity is exactly the same as when the matter was not collapsed.
It's just that the volume is very small, and gravity increases as you get closer to the surface.
The concept of color is tricky to apply to such objects. What you usually think of as the color of a surface is due to the light scattering from the surface interacting with your visual system. Since light does not escape the event horizon, then there is no color from there.
I think so.
Advancing personal theories is frowned upon here. Do you have any references to back up your thinking?
Gravity is a long-range force.
When you say Sun" think "star".
The event horizon of the black hole would increase.
Then the "solar system" includes stars and galaxies and... well... the Rest Of The Universe. So it is the same as asking about "what if the physics outside the Universe is different".
1. Baseless speculation is frowned upon here.
2. It doesn't matter - we can only know about this Universe.
3. The possibility that our Universe is inside a black hole has been explored.
That is a meaningless question.
I think you need to study more about black holes.
Starting from the quickie basics:
http://blogs.discovermagazine.com/ba...t-black-holes/
... to the more advanced geometry:
http://www.jimhaldenwang.com/black_hole.htm
... you'll probably want the stuff in between ;)
What you don't want to do is draw conclusions from pop-science TV shows.
CHeers.
Register to reply
Related Discussions
Black hole temperature derived from entropy (heat from black hole?) General Physics 3
Relativistic mass increase appearing to form a black hole vs. a real black hole Special & General Relativity 9
Time dilation and black-hole-black-hole mergers, and ringdown gravitational waves Special & General Relativity 13
Is it possible to escape a black hole's event horizon in a binary black hole system Astronomy & Astrophysics 6
Will a black hole revolve around a non-black hole object with greater mass? General Physics 2
