Register to reply
Effect of waves on offshore moored barge?!
by Makis
Tags: barge, effect, moored, offshore, waves
Share this thread:
Makis
#1
May19-14, 03:50 AM
P: 1
Hello PF members,
I would like to ask you a question regarding offshore moorings for barges up to 100 meters. More specific, I have a wave moving with 4 m/s and 3 meters height.
The dimensions of the barge are:
Length= 100m
Breadth= 37m
Depth= 7m
Loaded draft= 5.5m
Deadweight= 15,650 ton
The barge is moored with a line and the line is anchored on the seabed.
My question is, how can I calculate the effect of the wave on the aft surface of the barge (subsequently, to the whole body)? And, how this whole 'power', effects the line (thus, tension) and following, the anchor on the seabed?
I know that my question is a bit weird but I hope that you got the point of what I am trying to find :D !!!
Thank you in advance,
Makis
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
SteamKing
#2
May19-14, 07:19 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,546
Naval architects and ocean engineers perform mooring analyses of the type you asked about in the OP all the time, but the calculations are not simple and are usually done with the aid of special software. You probably can get an order of magnitude estimate of the forces involved with a few hand calculations, but this is still a complex problem to analyze in such a fashion, particularly the catenary effect of the mooring line, which is non-linear.
It's not clear what you mean by 'the effect of the wave on the aft surface of the barge'. The moored barge is going to surge, heave, sway, roll, pitch, and yaw in the seaway depending on the direction of the waves relative to the barge, and the catenary in the mooring line is going to add to the hydrostatic restoring forces and moments of the barge hull. The mooring analysis will determine the magnitudes of these forces on the barge and in the mooring line, so that you can determine if the anchor point of the line to the bottom has adequate strength.
Baluncore
#3
May20-14, 01:17 PM
Sci Advisor
Thanks
P: 1,923
Offshore, but how deep is the water?
Register to reply
Related Discussions
Rigid, Hydrogen Based, Moored Balloon General Engineering 3
A Horse Pulls a Barge in a River; What is the force of the water on the Barge? Introductory Physics Homework 15
Offshore oil drilling is safe? Current Events 797
I am an offshore oil worker Academic Guidance 3
Offshore Geothermal Drilling General Engineering 2
