Metal ring repelled from AC coaxial coil
The discussion centers on the phenomenon of mutual inductance, specifically how a metal ring is repelled when placed above a solenoid carrying alternating current (AC). The key principle involved is Faraday's Law of Induction, expressed mathematically as emf = -N * ΔΦ/Δt, where emf is the induced electromotive force, N is the number of turns in the solenoid, and ΔΦ/Δt represents the rate of change of magnetic flux. As the AC in the solenoid creates a changing magnetic field, it induces an emf in the ring, which generates a magnetic field that opposes the solenoid's field, resulting in repulsion according to Lenz's Law.
  • Understanding of Faraday's Law of Induction
  • Knowledge of Lenz's Law
  • Familiarity with the concept of mutual inductance
  • Basic principles of electromagnetism
  • Study the mathematical derivation of Faraday's Law of Induction
  • Explore practical applications of mutual inductance in electrical engineering
  • Investigate the effects of alternating current on magnetic fields
  • Learn about the design and function of solenoids in electromagnetic systems
Students and professionals in physics and electrical engineering, educators teaching electromagnetism, and anyone interested in the principles of electromagnetic induction and its applications.
nvalentour
I thought people helped on this forum?
If anything is unclear just ask, I'm checking for posts every minute. Come on people I have to get this done by 5 pm. I've gotten a little further. I believe it has something to do with mutual inductance.
A metal ring (no current) is brought close to a solonoid (coil with n turns), the solonoid has an alternating current running through it; explain using equations why the ring is repelled. (the ring is directly above the axis of the solonoid).
I think the di/dt of the coil induces an emf in the ring that follows Lenz's Induction Law and in turn creates a magnetic field with polarities facing each other, so they repel. I need this in equation form though. (Is my reasoning even correct?)... Please help.
The equation representing the phenomena is Faraday's Law of Induction:$$\mathcal{E} = - N \frac{d\Phi}{dt}$$where $\mathcal{E}$ is the induced emf, $N$ is the number of turns of the coil, and $\Phi$ is the magnetic flux. As the current in the coil changes, the rate of change of the magnetic flux also changes, and this induces an emf in the ring which opposes the change in flux and thus creates a repulsive force between the two objects.
Hello,
First of all, I want to assure you that people on this forum are always willing to help and provide assistance. It is possible that some may not have seen your post yet, or may not have the expertise to answer your question. I encourage you to be patient and give others a chance to respond.
Now, let's address your question. You are on the right track with your reasoning. The phenomenon you are describing is known as mutual inductance, which occurs when a changing magnetic field in one coil induces an emf in a nearby coil. This is described by Faraday's Law of Induction, which states that the induced emf is equal to the negative rate of change of magnetic flux through the coil.
In this case, the alternating current in the solenoid creates a changing magnetic field, which in turn induces an emf in the metal ring. This emf creates a current in the ring, which in turn creates its own magnetic field. According to Lenz's Law, this induced magnetic field will oppose the changing magnetic field that created it. Since the changing magnetic field in the solenoid is above the ring, the induced magnetic field in the ring will be in the opposite direction, resulting in repulsion between the two.
This can be expressed mathematically using the following equation:
emf = -N * ΔΦ/Δt
Where emf is the induced emf, N is the number of turns in the solenoid, and ΔΦ/Δt is the rate of change of magnetic flux through the solenoid.
I hope this helps to clarify your understanding. If you have any further questions, please don't hesitate to ask. Good luck with your project!
  • · Replies 51 ·
9K
