Fixing Broken Hartke 3500 Bass Amp with No Money
  • Thread starter Thread starter icvotria
    Amp Broken
The discussion revolves around the repair of a Hartke 3500 bass amplifier, specifically addressing a broken fan issue. Participants share their experiences, advice, and thoughts on DIY repairs, as well as the components involved in amplifiers.
  • One participant expresses concern about their lack of experience in fixing electronics but considers attempting the repair themselves.
  • Another participant emphasizes safety precautions, such as ensuring the amp is unplugged and being cautious of high-voltage components like capacitors.
  • There is a suggestion that a wire is unlikely to have come loose, and that cleaning the fan may be a more probable solution based on past experiences.
  • A participant shares their successful repair experience, noting that a loose plug was the issue and expressing excitement about the internal components of the amp.
  • There is a discussion about the terminology of "valves" versus "tubes" in amplifiers, with participants clarifying that they refer to the same component.
  • One participant expresses a desire to learn more about amplifier design and construction, indicating an interest in furthering their knowledge in electronics.
Participants generally agree on the importance of safety when attempting repairs, but there are differing views on the likelihood of specific issues (like loose wires versus fan cleaning). The discussion about terminology also highlights a minor disagreement regarding the use of "valve" versus "tube."
Some participants express uncertainty about specific technical details, such as the function of components within the amplifier and the implications of terminology used in electronics.
Individuals interested in DIY electronics repair, particularly those with a focus on amplifiers and audio equipment, may find this discussion beneficial.
icvotria
Hi, I've got a Hartke 3500 bass amp and the fan's broken. I need it fixed by Tuesday but I haven't got any money and the gaurruntee's expired :cry: I'm thinking a fan shouldn't be too hard to fix myself. Is this incredibly ill-advised? I know virtually nothing about how to fix stuff but I'm assuming it will all become apparent when I crack it open. It was damaged in a fall so I thought maybe a wire's come loose or something, this being the case I think I could fix it but I don't want to make things worse. Any advice?
Same thing once happened on my old Laney.
Firstly, I'm going to cover my arse. Don't mess about if you don't know what you're doing.
Secondly, I'm going to cover my arse again. I have no electrical qualifications, I just happen to have fixed a guitar amp's fan before.
As someone once said in another thread, there are three rules:
1. Make sure it's unplugged.
2. Make sure it's unplugged.
3. Make sure it's unplugged!
The least you can do is to open it up and have a look. You need to start being careful when you've got into the amplifier itself, you'll find some pretty big capacitors which are more than capable of giving you a nasty bite. If there's any risk of you accidentally touching the terminals, short them out using a voltmeter or something.
If you're not a regular tinkerer, be extra careful when disassembling your baby to make a note of which screws went where, what order things came apart in etc. Make drawings if you need to. It shouldn't be toooo complicated, but you might have to take knobs off (mark their positions first) and disconnect speakers (mark polarities), that kind of stuff. Just generally take your time and think about what you're doing.
Knowing amps, it's unlikely that a wire has come loose. If it has, you shouldn't have too much trouble soldering it back on again. But decent amps (especially bass amps, for big, fat, clumsy, bass playing buffoons) such as Hartkes are built to be thrown around stages and dropped down stairs, wires tend not to just come loose. Fans do wear out though, mine was so full of crud that it has just jammed up. A bit of a clear out and a few squirts of compressed air sorted it out, and all was well.
At the end of the day, unless you really spanner it up, you're unlikely to make things worse.
Good luck, let us know how you get on. Incidentally, what city are you in?
I'm in Huddersfield. Not so far from Manchester, maybe you could come fix it? :biggrin: :-p
Not far at all! You're not keeping an eye on that pie thread...
I think you should go give icvotria a hand, brewnog.
I think that is an excellent idea.
Then she'd find out that I don't really know what I'm talking about...
I fixed it! Hooray! I totally fixed it and it's all better. A little plug thing had come loose and I put it back in and now it works. Yippee! Thanks for your advice Brewnog, I think I'd've been too chicken to try if it wasn't for that post. It's really cool inside an amp. There was this really weird thing inside a glass case, it sort of put me in mind of a flux capacitator. I could have so much fun with my amazing time-travelling bass amp... Wow, I feel so good now I've fixed it, what a high! I'm going to go drop something else.
Fantastic news, good for you!
Things in glass cases? I didn't think those Hartkes were valve amps! Oops...
Ah well, at least I don't have to come all the way to Huddersfield now. Woo woo!
Ahhh, the mysterious valve, I've always wondered what these were for. Are they the same thing as a tube cos I found out that's what the thing in the glass case is. I wish I knew more about this kind of thing. I'll dedicate the summer to learning it all. Maybe.
Ic!
You're ENGLISH woman, they're valves, not tubes!
But yes, they're one and the same. I actually looked into designing and building a small valve amp for my guitar a few years ago, but never quite got around to it.
No ic! It wasn't my fault... Now I know, I'll never say 'tube' again. I was hoping they were the same thing cos valve-amp sounds really cool and 70's, it must be the inherrent British in me. I'm thinking of putting a guitar together from my friends' old parts, should be interesting...
  • · Replies 28 ·
33K
14K
  • · Replies 38 ·
